Leaks Between Spark Plugs & Head
Topic author - Posts: 23
- First Name: David
- Last Name: Tipton
I have a 1915 Touring with the original head. I had the motor and transmission rebuilt about 4 years, alum. pistons, scat crank, stainless valves & seats, etc. Yesterday when I drained and refilled the radiator some accidentally splashed into the 1st and 2nd spark plug dimples on the head. When I started to crank the motor I saw bubbling around the spark plug threads, I tightened the plugs as much as possible but to bubbling is still there. This is happening around all 4 plugs even after tightening. I don't think this is a new problem I happen to notice it because I splashed coolant on the head while refilling.
The plugs are new Champion 25's. I would appreciate all suggestions/help.
Thanks,
David Tipton
Colleyville, TX
Thanks,
David Tipton
Colleyville, TX
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Re: Leaks Between Spark Plugs & Head
Actually kind of common. You'll hear everything from Teflon tape (white & Yellow) to tin foil on the threads. Yellow Teflon is my choice.
It's a problem only if it lowers compression or if you let a lot of water leak into the cylinders, but foil or Teflon tape are OK. Some are afraid the tape will unground the plugs, but the threads will cut through it and contact the head.
- First Name: George P
- Last Name: Clipner
I had the same issue on my Z Head. I have used tin foil but had issues removing the plugs. I use anti seize now and no issues. A few years back, Champion made some new X's with bad threads that would leak. The new ones I'm running don't have that issue but did have seepage on the Z Head. Anti seize works for me.
- First Name: Kirk
- Last Name: Peterson
- * REQUIRED* Type and Year of Model Ts owned: 27 Touring 24 Coupe
George
Anti seize works good for me too.
Kirk Peterson
Santa Fe NM
Santa Fe NM
- First Name: David
- Last Name: Tipton
Any particular brand of Anti Seize?George N Lake Ozark wrote: ↑Wed May 08, 2019 5:19 pmI had the same issue on my Z Head. I have used tin foil but had issues removing the plugs. I use anti seize now and no issues. A few years back, Champion made some new X's with bad threads that would leak. The new ones I'm running don't have that issue but did have seepage on the Z Head. Anti seize works for me.
Thanks,
Dave Tipton
- First Name: David
- Last Name: Tipton
- First Name: Kirk
What ever the Parts store has in stock.
Kirk Peterson
Santa Fe NM
Santa Fe NM
- Last Name: hardiman
- * REQUIRED* Type and Year of Model Ts owned: 26 coupe
Cooper.... takes the heat...use it on engines I have rebuilt ..non t.
I use ether anti-seize or white teflon tape, which ever I have at hand at the time. I have some old anti-seize with lead in it (known in California to cause all kinds of nasty things to the body if you eat it!
), but as said above what ever brand.
