Headlights to big for Model T Price Lowered
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Apr 12, 2023 11:14 pm
These are large for a T and I was very disappointed. They look like Cadillac but have no MFG. on them. The forks & lights are large they have 1916 patent # for Mc Beth with green shaded lenses ( one has a chip but is not noticeable) These should be worth a lot I will take $350 Now $325+ shipping for them. email or call 6zero2- 7six9-zero25sevan There is one of these lenses on Ebay for $159
Headlight 15.jpg (32.24 KiB) Viewed 2525 times
Headlight 16.jpg (32.17 KiB) Viewed 2525 times
Headlight 17.jpg (32.84 KiB) Viewed 2525 times
Headlight 18.jpg (30.09 KiB) Viewed 2525 times
flatbroke3
First Name: harold
Last Name: musolf
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
Board Member Since: 2010
Re: Headlights to big for Model T
Post by flatbroke3 » Thu Apr 13, 2023 11:35 am
'14 cadillac
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Apr 13, 2023 11:45 pm
Thanks Harald,
I was thinking the same period Cadillac but all the examples i have found had Cadillac engraved on them ???
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Fri Apr 14, 2023 12:49 pm
Cadillac used Gray & Davis lamps which these are not. A close look at the knobs that hold the doors shut will probably show the manufacturer as Solar.
This style lamp was called French style. These are the Solar interpretation whereas Cadillac used Gray & Davis French style. Where the mounting brackets attach is the give away. The body of these is straight while Cadillac has a body that tapers.
The lenses are later replacement accessories.
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Apr 14, 2023 3:47 pm
Thank You Layden,
I will check the harware for markings, any idea what they would have come off of?
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Apr 14, 2023 4:23 pm
Layden is correct they have SOLAR E-418 on the bezal nuts.
First Name: craig
Last Name: leach
Post by Craig Leach » Sat Apr 22, 2023 11:05 pm
Lets try again.
First Name: craig
Last Name: leach
Re: Headlights to big for Model T Price Lowered
Post by Craig Leach » Wed May 24, 2023 12:23 pm
To THe Top
gravelguy
Last Name: Stormo
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster
Post by gravelguy » Sun Mar 16, 2025 8:44 pm
PM sent
Mike Stormo
