Lower radiator shell screw size
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Post by Plankhill » Mon Apr 17, 2023 8:11 pm
What is the screw size for the screw that holds the lower radiator apron to the front motor mount on a 26-27?
Moxie26
Last Name: Jablonski
Re: Lower radiator shell screw size
Post by Moxie26 » Mon Apr 17, 2023 9:31 pm
I believe it's the same screw size and design that holds the inspection door on the transmission
Post by DanTreace » Tue Apr 18, 2023 3:33 pm
That button head machine screw for the '26-'27 radiator apron with the 3075D spring clip/motor mount with the threaded hole is Fac. # T-8004. The size is 1/4 x 20 x 3/8" long. Some times a washer is needed under the screw if the hole in the apron is worn larger.
The hogshead cover door screw is also button head, but larger, as it's 5/16" x 18 x 3/8"
Moxie26
Post by Moxie26 » Tue Apr 18, 2023 11:20 pm
Thanks for the clarification Dan, appreciated.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Thu Apr 20, 2023 1:13 pm
Just did one yesterday and looked like 1/4 - 20TPI
1912 Torpedo Roadster
