Amp gauge
Divcoone
Last Name: Giles
* REQUIRED* Type and Year of Model Ts owned: Speedster
Amp gauge
Post by Divcoone » Wed Apr 19, 2023 9:06 pm
Could this be a Model T amp gauge. It has a flat bezel.
Bob Giles
Re: Amp gauge
Post by DanTreace » Wed Apr 19, 2023 9:32 pm
Yes
That is '26-'27 ammeter for the Improved Ford.
26 27.jpg (63.53 KiB) Viewed 857 times
Re: Amp gauge
Post by TRDxB2 » Thu Apr 20, 2023 1:03 am
The 20-0-20 range, Ford script face plate, flat bezel and dark background behind the pointer appear to be an original . Assumed it will fit a 1-5/8" hole. I'm a little uncertain about case because of the indented bar on the back & that the bezel appears to be a bit loose around it, should be a toght fit unless the bezel has some splits (need to check some). The rubber knobs are repro.. In any case polish up the bezel should be nickle finish - it looks good!
