krylon gloss black
tdump
First Name: Mack
Last Name: Cole
krylon gloss black
Post by tdump » Wed Apr 26, 2023 7:53 pm
Am I the only 1 that can not find a can of normal krylon gloss black any more? It is missing in every store I used to buy it from.It looks better on some stuff than rustoleum.How black can be different is confusing.But i can't find anything but 2x and fusion.
Last Name: Strange
Re: krylon gloss black
Post by CudaMan » Wed Apr 26, 2023 8:05 pm
I used to use Krylon, but their spray nozzles seemed to clog up after only one or two uses, wasting most of the paint in the can.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Wed Apr 26, 2023 11:10 pm
This is the kind I am speaking of, I know the tall can is not normal but for whatever reason, it has went POOF
https://www.walmart.com/ip/Krylon-Rust- ... /763785141
Notice the out of stock?
I used to buy it at the local walmarts
BobD
First Name: Bob
Last Name: Doris
Post by BobD » Wed Apr 26, 2023 11:56 pm
tdump, I clicked on your link and it brought me to my local Walmart here in AZ and it appears to be available here.
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Apr 27, 2023 2:59 pm
Hi Mack,
Have you tried Rustoleum black engine paint? It costs more but covers better & shines better. Someone told me they painted a replacement
fender on their T and it looked like a pro job.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Thu Apr 27, 2023 3:15 pm
Naw I haven't. I use Rustoleum on alot of stuff but it seems on sheet metal the krylon has a better "shine"?
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Thu Apr 27, 2023 6:26 pm
Well I dug around on the net and found a way to ask the company and this is the reply I got.
Gee thanks folks for taking a useful product away from us :cry: The plan is to ask which paint is nearest to the same shade and see if I get a reply/
Web - Krylon <krylonsfdc@sherwin.com>
You
Hello Mack,
Thank you for contacting Krylon. We appreciate your inquiry.
Unfortunately this product has been discontinued. We are sorry for the inconvenience. Please let me know if you have further questions or concerns.
Kind regards,
Alex
Post by Scott_Conger » Thu Apr 27, 2023 7:49 pm
Mack
I believe that you got only a partial answer from that rep.
I, too, have run into issues with Krylon and not being able to find a particular P/N for love or money. I have found in every instance after exhaustive internet searches as well as email with representatives that in nearly every case (every case for me) that either the quantity size is discontinued, or the part number has changed but you can still, in fact, buy the same product you want (either in a different size can, or through a different part number).
My latest example was their "satin black" which I use for engines and a few suspension parts.
Good Luck, and keep trying.
Professor Fate
Last Name: S
Post by Professor Fate » Thu Apr 27, 2023 10:33 pm
I have used this stuff with outstanding results. High flow tip allows for paint to lay on wet, not partially dry like with a lower flow nozzle. Solvents begin to flash off about 20 mins after spraying, leaving a soft but dry surface within 90 mins. Takes about 4 days for paint to harden up as solvents continue to be released.
Surface can be wet sanded and buffed.
[/size]
________________
**FATE**
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Fri Apr 28, 2023 12:03 pm
You
Hi Mack,
Rust Tough with Anti Rust technology would be the nearest match, the part number for the Semi Gloss Black is K09267008
I hope this information is helpful. Please let me know if you have further questions or concerns.
Kind regards,
Alex
