Side lamp fonts
Belliott3
First Name: Bill
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Board Member Since: 2006
Side lamp fonts
Post by Belliott3 » Fri Apr 28, 2023 7:44 am
Concerning the “black era” model t side lamps (1916-25) were the lamps interchangeable? It seems like the only thing distinguishing between left and right is the font. Can the fonts be used interchangeably?
First Name: Jeff
Last Name: Humble
Re: Side lamp fonts
Post by Humblej » Fri Apr 28, 2023 7:59 am
Yes, they are the same 1916-1927.
Belliott3
First Name: Bill
Last Name: Elliott
Re: Side lamp fonts
Post by Belliott3 » Fri Apr 28, 2023 8:07 am
I kind of thought so. So the font position makes it left or right, not the body.
Re: Side lamp fonts
Post by DanTreace » Fri Apr 28, 2023 9:05 am
The body of the cowl lamp has the bayonet lock with the left and right side cutaways for the wick adjusting knob shaft.
Place the font with the burner assembly so the adjusting shaft and knob exit for left or right car mount.
