Floor blueprint
FULLBORE
Last Name: Coats
Floor blueprint
Post by FULLBORE » Sun Apr 30, 2023 11:40 am
Is there a website with a drawing of a model t floor. I need the location and diameter of the starter switch hole.
Last Name: House
Re: Floor blueprint
Post by George House » Sun Apr 30, 2023 12:02 pm
What model year ? What body style ?
FULLBORE
Last Name: Coats
Re: Floor blueprint
Post by FULLBORE » Sun Apr 30, 2023 1:28 pm
1927 touring.
Been Here Before
First Name: George John
Last Name: Drobnock
Re: Floor blueprint
Post by Been Here Before » Sun Apr 30, 2023 2:57 pm
https://www.mtfca.com/discus/messages/8 ... 1529376441
Been Here Before
Last Name: Drobnock
Re: Floor blueprint
Post by Been Here Before » Sun Apr 30, 2023 3:10 pm
OR
Moxie26
Last Name: Jablonski
Re: Floor blueprint
Post by Moxie26 » Sun Apr 30, 2023 3:52 pm
George.. that drawing may be reference to a 26-27 four-door sedan or a TT truck since it shows the gas tank under the front seat. He has a 27 touring car.
FULLBORE
Last Name: Coats
Re: Floor blueprint
Post by FULLBORE » Mon May 01, 2023 7:12 am
Thanks for the drawings, but I don’t believe they show the hole for the starter switch.
I’m actually looking for the starter switch hole diameter and location
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Floor blueprint
Post by Humblej » Mon May 01, 2023 7:45 am
Mike,
Dont have the drawing. You can get one from the Benson Ford Research Center, its complicated and costs money. If this helps, decades ago my father made new a floorboard using the original as a template, I cannot vouch for its accuracy. The hole is 1 3/8" dia, and all measurements are perpendicular to the edge of the floorboard.
FULLBORE
Last Name: Coats
Re: Floor blueprint
Post by FULLBORE » Mon May 01, 2023 8:08 am
That is exactly what I need.
Re: Floor blueprint
Post by Allan » Mon May 01, 2023 8:11 am
Why not just map the position of the starter button and drill the floorboard to suit? At least that way any differences between cars will be negated and your drilled hole will be concentric to your particular starter button.
