Identify radiator year
ModelTED
First Name: Ted
Last Name: Hacker
* REQUIRED* Type and Year of Model Ts owned: 1922 Roadster - 1923 Huckster - 1924 Truck
Post by ModelTED » Sun May 07, 2023 10:28 pm
I need some help identifying year of Radiator. I believe to be between 1914-1916 based on what the encyclopedia says and various other posts.
I dont know how to ready the data tag on the back, not sure the numbers mean anything ? Looking to use on my Power Unit project. After re-core of course.
Thanks in advance.
Re: Identify radiator year
Post by Steve Jelf » Sun May 07, 2023 10:50 pm
There's no tube for gas headlights, so it's not 1914. 1915 or 1916? I don't think there's any difference.
Post by Allan » Mon May 08, 2023 1:32 am
Somewhere in the time line the neck was riveted as well as soldered, the rivets coming later in production.
ModelTED
First Name: Ted
Last Name: Hacker
Post by ModelTED » Tue May 09, 2023 10:56 pm
Guys,
Thanks for the replies.
1) No gas tube - I noticed that but not knowing what to look for, I did notice the two holes in the side trim. Is that where the tube would go or is that for the electric wires to pass through?
2) rivets / solder - Attached is a close up of the neck. Does this help?
Post by Allan » Tue May 09, 2023 11:28 pm
The rivets put it at the end of brass radiator production. How close to the end I do not know. I was told my 1915 tourer should have them, but not my 1912 van.
Last Name: van Ekeren
Post by Kerry » Tue May 09, 2023 11:55 pm
According to the encyclopedia, the drawings to indicate the rivets for filler neck, was October 1911.
Post by Allan » Wed May 10, 2023 7:27 am
I hope you are correct Frank. The neck I had for my van was drilled for rivets, so I used it when assembling the radiator onto an original new old stock core.
FordFool
First Name: Don
Last Name: Kirtley
* REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
Board Member Since: 2009
Post by FordFool » Wed May 10, 2023 9:26 pm
15/16 had a tube for the left head lite.
Post by Original Smith » Thu May 11, 2023 11:31 am
It is most likely a mid to late '14. I haven't seen a '14 with the stamped serial plate that low yet. They moved it up around 1915.
ModelTED
First Name: Ted
Last Name: Hacker
Post by ModelTED » Wed May 17, 2023 9:08 pm
do the numbers in the serial plate mean anything? Do they match the serial number of the engine? If so this would make it Oct. 1914?
Last Name: Wrenn
Post by TWrenn » Thu May 18, 2023 11:29 am
No they have nothing to do witj the engine number. Not all rads were even made by Ford. I believe these are specific to the maker of the radiator.
Post by Steve Jelf » Thu May 18, 2023 12:11 pm
True for early years. By the end of 1912 all were made by Ford.
