looking for a 12 tooth pinion to put in my roadster. Suppliers do not seem to have them in stock.
Thanks for the tips guys, I do have the recessed 40 tooth Ruckstell ring gear and I do have Rocky Mountain brakes. I With the lightness of the roadster and good running engine I think the 3.07:1 or 3:33 ratio will be what I want. I did find a 13 tooth.
WTB: 12 or 13 tooth pinion
popeyet
Topic author - Posts: 50
- First Name: CHRIS
- Last Name: MCINTYRE
- * REQUIRED* Type and Year of Model Ts owned: 21 touring, 15 roadster
- Board Member Since: 2023
got10carz
- Last Name: Meixner
Re: 12 or 13 tooth pinion
Only trying to help. You know you need the recessed ring gear to use either of those pinions. Chaffins is a wealth of knowledge about this.
In the spirit of helping, a 13 tooth pinion will give a considerably higher diff ratio, and severely compromised braking. You will need auxiliary brakes for safety.
Edit your title and put wanted in it.
