FRONT FLOOR BOARD SUPPORTS
Sanary22FT
First Name: Stephane
Last Name: Lezzier
* REQUIRED* Type and Year of Model Ts owned: Touring US 1918
Board Member Since: 2022
Post by Sanary22FT » Mon May 15, 2023 2:41 pm
Hello, i found this parts.
Where do you buy ?
S-176 - 22-25 TOURING AND ROADSTER FRONT FLOOR BOARD SUPPORTS (PR)
Thanks for the help
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: FRONT FLOOR BOARD SUPPORTS
Post by Dan McEachern » Mon May 15, 2023 7:12 pm
Stephane- If you are looking to buy, I think I have an original set.
There are a few tears that will need repair but overall very useable.
here are a few pictures. My e-mail is dmcgearsATyahooDOTcom.
Sanary22FT
Last Name: Lezzier
Post by Sanary22FT » Tue May 16, 2023 2:58 pm
But it is not a same to ask for my 1922 Touring
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Post by Shannon_in_Texas » Tue May 16, 2023 3:49 pm
Have you checked with Howell's Sheet Metal directly? Best to call them but they are sometimes hard to get ahold of if they are out in the shop-- just keep trying.
https://fordor.com/category.cfm?cat=192 ... 0927modelt
You might also check with Chaffin's (chaffinsgarage.com) or Lang's (modeltford.com); both are great to deal with.
And, put up a wanted ad here if you would like to find a pair of originals and someone may have a set for you. Good luck!
Post by Scott_Conger » Tue May 16, 2023 3:54 pm
Dan
I suspect that your parts might be from an enclosed car (?)
this is what Stephane needs:
It does look like Howell's is the source of them as new
Dan McEachern
First Name: DAN
Post by Dan McEachern » Tue May 16, 2023 10:54 pm
HI Scott- you might be correct regarding the correct supports. Perhaps someone else will need the ones I have for their project.
Mine obviously have provision for the three body mount bracket bolts to pass thru the supports I have.
