Upper Center Main Bearing
Vrayfoster
First Name: Victor
Last Name: Foster
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1915 Touring
Board Member Since: 2002
Post by Vrayfoster » Thu May 18, 2023 6:12 pm
Does anyone know what engine number Ford started putting in the upper center main bearing?
Re: Upper Center Main Bearing
Post by Mark Gregush » Thu May 18, 2023 6:24 pm
All the upper mains in the block were left unbabbitted not just the center. Starting around engine No.38,263 Feb 14th. 1911 some were babbitted with enclosed valve chamber then around 46,236, all engines had the upper babbitt and enclosed valve chamber.
Vrayfoster
First Name: Victor
Last Name: Foster
Post by Vrayfoster » Thu May 18, 2023 7:05 pm
Thanks for the info. I just bought a '10, and I wondered if this engine was one with the upper center main without Babbit.
