Wanted to Buy - Rear Budd Wire Wheel Hubs and Hubcap Wrench
David Greenlees
First Name: David
Last Name: Greenlees
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T racing car, 1924 Model T Depot Hack with original York #803 body.
Post by David Greenlees » Fri May 19, 2023 5:40 pm
Wanted: Budd T Ford left and right rear hubs in usable or restorable condition, the hub caps are not needed but will purchase for spares. The outer end of the hub which is threaded inside is 1-23/32" or 1.718" on the outside diameter
and 1.275" or 7mm on the inside diameter. The OD of the hub cap threads is 1-11/32" or 1.344.
budd wire wheel wrench.jpeg (16.36 KiB) Viewed 1270 times
Wanted: Budd 1-7/8" wrench wire wheel in usable condition.
Photo courtesy of Dan McEachern.
Email at the contact link below my name and location. OR call or text @ eight-O-two-four-nine-O-six-five-O-nine
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Re: Wanted to Buy - Rear Budd Wire Wheel Hubs and Hubcap Wrench
Post by frontyboy » Sat May 20, 2023 12:05 am
I have a real Budd wheel wrench, extra to me, also have a rare Budd rear wheel carrier bracket, This is a factory unit using a front hub as the wheel mount. This attaches to the rear cross member with a goose neck shape.
Both are forsale
frontyboy2oh6-919-1949(Seattle) text or call.
Monmarte
First Name: Mon
Last Name: marte
Post by Monmarte » Mon May 22, 2023 4:12 am
Both are forsale
G Switch
In the past I used to buy a lot of parts from scrap yards to get them at affordable prices. But it's different now, with parts and tools like this that can't be found in the dump. :geek: :geek:
Southfork Creek
Last Name: Wightman
Post by Southfork Creek » Tue May 30, 2023 8:21 pm
Hi David, The rear Budd hubs I have are not Model T. Rollie
