Wanted Chicago trans case
t-time
Topic author - Posts: 181
- Last Name: Bruto
- * REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Going through a Chicago transmission and discovered the case has been welded. I would rather not use it so I'm looking for another.
Michael Peternell
- First Name: Michael
- Last Name: Peternell
- * REQUIRED* Type and Year of Model Ts owned: TT gas truck, T tractor conversions, '15 touring, '17 speedster, '26 16 valve speedster
Re: Wanted Chicago trans case
There are two different Chicago cases. One says patent pending the other does not. Different bearings between the two. I've got one you can have for the cost of postage. Might get a little spendy MN to CA. You can let me know if you can't find one closer.
Mike Peternell
Mike Peternell
t-time
- Last Name: Bruto
This one has patent pending in the casting. Thank you
t-time
- Last Name: Bruto
A case has been located. thanks to everyone who responded.
TeveS-Nor Cal
- Last Name: Straw
- * REQUIRED* Type and Year of Model Ts owned: 1915 and lots of parts
Have you opened it?
t-time
- Last Name: Bruto
I have, I've seen worse. I'll start with evaporust and see what it will do. Thanks again.
