If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
Post
by Steve Jelf » Fri May 26, 2023 11:41 am
Consequently, the bottom part of the magneto coil assembly has a certain amount of spring to it, and may be attracted into actual contact with the brass plates over the magnets when the powerful current from the storage batteries is sent through the windings, thus giving greater magnetizing effect.
~ Murray Fahnestock
I've never seen any brass magnet plates. I've never even heard of them. Were they actually used at some point, or is this just a typo?
Post
by Norman Kling » Fri May 26, 2023 2:10 pm
The article by him in the booklet "Electrical System" says brass screws.
Nv Bob
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Post
by Nv Bob » Fri May 26, 2023 3:11 pm
Not seen brass plates but brass spools yes
- Last Name: van Ekeren
Post
by Kerry » Fri May 26, 2023 5:24 pm
Wouldn't work, must be a typo.
J1MGOLDEN
- Last Name: Golden
Post
by J1MGOLDEN » Sat May 27, 2023 1:11 pm
I just upgraded a 1917 transmission, to a 1920 with a starter, that had a double mag coil ring and brass spools to support the magnets.
Wheter this was original or just a use of available earlier parts is a total unknown for me.
