USED rear car axle spiral wound roller bearings part # 2508, these are for both inner and outer and left and right side, lightly used very good condition and measure .002" wear or less on the rollers, no loose cages, limited number available, most have no makers markings but some say Hyatt and a few Ford, all are the original style spiral wound rollers and probably date from the 1920s, they have been cleaned in solvent but you should clean again to get any residual out of the inside of the rollers, price is $75 each, domestic postage is a flat $15 per order regardless of the number ordered.
Also have 2 bearings that measure .003" wear, same tight cages, price is $110 for the pair including domestic postage.
Spiral wound rear axle roller bearings F/S
Topic author - Posts: 1714
- First Name: Layden
- Last Name: Butler
- Last Name: Butler
Re: Spiral wound rear axle roller bearings F/S
Happy buyers so far! I would like to clear out the remaining so 10% off!
