Wednesday, getting closer to Richmond with a “B”. “It’s alive.”
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Wed May 31, 2023 10:38 am
Sean Butler
First Name: Sean
Last Name: Butler
Re: Wednesday, getting closer to Richmond with a “B”. “It’s alive.”
Post by Sean Butler » Wed May 31, 2023 11:33 am
Thanks for that, Rob. An awesome machine. Always enjoy your videos - both the content and the little extra production tidbits. :D
Sean Butler
Huntington Beach, CA
Post by Jerry VanOoteghem » Wed May 31, 2023 11:54 am
Smile Rob! :)
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Wed May 31, 2023 1:15 pm
Cool! Sounds about the same as when I started it. I thought it might quiet down a bit. Did you make a different breather?
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Wed May 31, 2023 1:47 pm
Post by Wayne Sheldon » Thu Jun 01, 2023 1:59 am
Wow. Just, WOW!
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Thu Jun 01, 2023 5:07 am
Kim,
It’s quieter, although the audio on the phone video may not be very accurate. Kept everything the same, however put in slightly taller pistons. Compression is about 55 lbs now (was on average 45 before). It seems “stronger,” although we’ve not tried it much and starting slow with the break in.
Farmer J
Last Name: Kramer
* REQUIRED* Type and Year of Model Ts owned: 3
Post by Farmer J » Sun Jun 04, 2023 1:00 pm
For those of you wondering if Rob made it to Richmond with the B. He did and it was well worth the wait. What a beautiful car. It won what I’m sure will be the first of many trophies. Rob also brought along his K and his racer. A big thank you from the MTFCA and those here in Richmond to all of you guys for bringing your cars for everyone to see.
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Mon Jun 05, 2023 7:53 am
Thank you Jerry,
Speaking for all the Early Ford participants, we had a great time. Great car show and events made the Homecoming an event to look forward to in the future. I hope to be back next year and participate in the tours too.
A few photos:
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Mon Jun 05, 2023 8:17 am
1907 R runabout:
1908 S Roadster:
1905-06 F with tonneau:
1906-08 N runabout:
1905 C with tonneau:
Post by Dollisdad » Mon Jun 05, 2023 9:03 am
Rob, thanks for the pictures of the early Fords. I hope to attend this show in the future.
jab35
Last Name: Bartsch
Post by jab35 » Mon Jun 05, 2023 9:45 am
Thanks, Rob and others sharing your Homecoming posts.
Rob, is the 'Green' paint on the '05-'06 F and the '07 R a custom color mix or is it available from the paint supplier? If commercially available, do you mind sharing the information and source? Thanks, jab35 at cornell dot edu
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Mon Jun 05, 2023 12:49 pm
I sent an email to Peter at Fawcett Restoration. He usually tries to find a “on the shelf” color so we can retouch things. I’ll get back to you.
Cheers,
Rob
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Mon Jun 05, 2023 1:23 pm
James,
That was fast. From Peter: “The green is code #5223A and the yellow is code #2425A.
We get our paint from Carquest.”
