Torpedo firewall bracket
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Fri Jun 02, 2023 1:40 am
Hi All,
I am working on a 1911 Torpedo.
To do the job right I am looking for the firewall to frame bracket set.
In the parts catalog from Chaffin's Garage I found the part number for these brackets 3640/41T.
Since a few days I am trying to contact them for asking if they have them in stock but can't get an answer.
Maybe somebody out there can help me with that.
Andre
Belgium
torpedo brackets.jpg (39.05 KiB) Viewed 3025 times
Last Name: Wrenn
Re: Torpedo firewall bracket
Post by TWrenn » Fri Jun 02, 2023 10:02 am
Just keep trying, they get pretty busy.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Fri Jun 02, 2023 10:21 pm
Andre, Since you are calling from EU. I can get thru to Dave ask about the availability and relay back to you?
Check the timing of your calls. Let me know if I can help,,,
1912 Torpedo Roadster
AndreFordT
First Name: Andre
Post by AndreFordT » Fri Jun 02, 2023 11:54 pm
Please Gene,
If you can help it will be great.
Andre
Belgium
Andrew Brand
First Name: Andrew
Last Name: Brand
Post by Andrew Brand » Sat Jun 03, 2023 2:50 am
Hi Andre
I have an original pair (not for sale - for my Torpedo). If you can't get them and need dimensions to make them, I can help.
Andrew
AndreFordT
First Name: Andre
Post by AndreFordT » Sat Jun 03, 2023 9:38 am
Yes Andrew,
It will be a great help if I had the dimmensions to make these brackets.
Selling yours should be easier, but ... :lol: :lol:
Have a fine day.
Andre
Belgium
ahovey
First Name: Austin
Last Name: Hovey
* REQUIRED* Type and Year of Model Ts owned: ‘11 Torpedo
Board Member Since: 2014
Post by ahovey » Sat Jun 03, 2023 9:42 pm
Andre,
I responded to your post last year on this with a few dimensions. https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=26704
Let me know if I can be of any other help with dimensions or anything else. I had detailed engineering drawings made for these brackets.
Austin
AndreFordT
First Name: Andre
Post by AndreFordT » Sun Jun 04, 2023 2:42 pm
Thanks Austin,
I couldn't find this post.
Do you have other messurment about these brackets?
I think the only way to do this right is to make the brackets myself but there for I will need good drawings.
Andre
Belgium
SurfCityGene
First Name: Gene
Post by SurfCityGene » Tue Jun 06, 2023 6:39 pm
Andre, I just talked to Dave at Chaffins and he has ONE set of those brackets in stock. I'm not sure if you were using the New Number and allowed for the time difference? Chaffins new number is 1-951-226-7331, New address518 N Spring St Lake Elsinore, Ca. 92530
Hope this helps
SurfCityGene
First Name: Gene
Post by SurfCityGene » Tue Jun 06, 2023 6:44 pm
Andre
You might also email them at support@chaffinsgarage.com Their hours are 8AM to 5PM Pacfic time Monday thru Friday
AndreFordT
First Name: Andre
Post by AndreFordT » Wed Jun 07, 2023 9:22 am
Gene,
I just send a mail to Dave to order the brackets.
At This time I am in the South of France till next Monday and will try to get them on the phone.
Andre
Belgium
AndreFordT
First Name: Andre
Post by AndreFordT » Mon Jun 12, 2023 10:34 am
Thanks All,
Parts are on the way to us.
Thanks Dave to help .
Andre
Belgium
