Broken Crank Club
Rod
Topic author - Posts: 90
- First Name: Rod
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
- Board Member Since: 2014
Broken Crank Club
Well it finally happened to me. During the Thursday tour at the MTFCA, I broke a crank on my 24 Depot Hack. We were on the return trip from the Carillon Historical Park and about 10 miles from the MTFCA Museum when it happened. A loud knocking from the engine and we pulled over. A few minutes later, here comes Jerry Kramer to the rescue. He was only a few miles from his house. He drove his T there and returned with a truck and trailer. THANK YOU JERRY!
Fortunately, I have been saving a SCAT crank at the house in case this ever happened. I will pull the engine and take it to Ron's Machine Shop to get in the que for a total rebuild.
Rod
Rod
Gracie'sDad
- Last Name: Dow
Re: Broken Crank Club
Admission into the brotherhood is testament to the fact that you have finally arrived. I joined 3 years ago and am better for it. Welcome my friend, we have been waiting for you.
KeithG
- First Name: Keith
- Last Name: Gumbinger
Sad of course, but it could have been worse.
Cheers,
Keith
Cheers,
Keith
Model T Mark
- Last Name: Eyre
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
I joined 22 years ago, not fun! Hang in there!
I joined the club 4 years ago, after almost 50 years of T driving. Keith said it could have been worse! My son had the block destroyed when he had a break. Cross your fingers that you don't have the same.
Hoping for the best.
Racer_22
- First Name: Kevin
- Last Name: Prus
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1912 torpedo, 1914 touring, 1919speedster, 1921 touring, 1922 touring 1925TTsemi, 1926 pickup, 1926 roadster
- Board Member Since: 2004
I will have a new Skat T crank at the Homecoming swap meet in the morning.
Kevin Prus
Kevin Prus
Racer_22
- First Name: Kevin
- Last Name: Prus
Also have a new 290 cam at the homecoming swap meet
Fire_chief
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),22Touring,22 TT,21 Fire Truck,14 Chief Car
It's a tough club to join, but I achieved my membership many years ago. I then renewed that membership. The solution was to use Scat cranks in my rebuilds, as can be attested to Kevin. I now keep a few Scats on hand, for myself or close friends.
- Last Name: House
Yep… happened to me too back in ‘76 on the Glidden Tour in Colorado. I determined the cause at the time. Do you have any idea as to the ‘why’?… I feel your pain
BHarper
- First Name: Bill
- Last Name: Harper
- * REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Hello Rod,
My condolences for your misfortune. You were wise to put aside a Scat crankshaft for the day which you knew would come as they can be on a months long backlog.
I am a two time member of the club.
Bill Harper
Keene, New Hampshire
Sad! This is one of he weak points of the Model T. My grandfather told of that happening back in 1926 with a car only a couple years ago. Happened on a cross country trip. The car was towed into a Ford dealer and fixed overnight. Now I don't think a Ford dealer would even know much about Model T's.
Sorry for your problem.
Aussie16
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 RHD Canadian Touring 1916 Pickup 1926 Fordor 1925 Dalgety Tourer 1916 Speedster
Look on the bright side. If you have broken one, It means you have also had the pleasure of driving your T. I drove for 25 years, numerous T's and many thousands of miles before it finally happened to me! Wouldn't trade those miles for anything! Also have learned a lot about how not to drive and also how to preserve the life of a crank. I think many breakages are a result of poor driving habits, poor set up and just plain old worn out motors. Well sorted and rebuilt to proper specs will surely reduce the chances of a breakage.
Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Question: I’m in N.J. Exactly where would I have to ship my block for babbit replacement and what would the approximate cost be including one of the later cranks?
Moxie26
- First Name: Robert
- Last Name: Jablonski
Charlie.... Our local babbitt machine shop is in Strasburg Pennsylvania .,..... Schwalms Babbitted Bearings , still run by Ora Landis. ... www.schwalms.com. ..... This shop did our engine over 20 years ago..., His shop is just down the hill on Georgetown road a little bit south of the railroad Museum.
Charlie B in N.J.
- Last Name: BRANCA
Moxie26
We did the same, and the trip wasn't that bad.., Ora's father passed last month.
