Flatten hills with a Full Flow Valve™ for your NH
Post by Scott_Conger » Sun Jun 11, 2023 11:59 am
Bucking and snarfing on hills? Surging? Can't keep up? Just HAVE to have a fuel pump??
It's probably because you're handicapped with a bad repro float valve which strangles fuel flow! All Full Flow Valves come standard with a LEAD washer to get the best seal possible.
go from standard repro on the left to the Full Flow on the right
standard vs full flow.jpg (32.95 KiB) Viewed 1737 times
Full Flow Float Valve.jpg (39.27 KiB) Viewed 1737 times
special installation tool available as well as special taps to clean out all the threads
EMAIL for information
mike37 cdn
First Name: mike
Last Name: mclean
Re: Flatten hills with a Full Flow Valve for your NH
Post by mike37 cdn » Sun Jun 11, 2023 2:50 pm
email sent mike
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Jun 11, 2023 5:36 pm
Very nice work as always Scott!
Last Name: Hatch
Post by Dan Hatch » Sun Jun 11, 2023 6:08 pm
If you don’t have one you better get one.
Tmooreheadf
Last Name: Moorehead
Post by Tmooreheadf » Sun Jun 11, 2023 9:06 pm
These work very well and really do well on hills when the gas tank is low of fuel. The removal tool works very well too. I highly recommend both!
Post by Original Smith » Mon Jun 12, 2023 11:30 am
Are you selling to us people in California yet?
TeveS-Nor Cal
Last Name: Straw
Post by TeveS-Nor Cal » Thu Jun 15, 2023 8:55 pm
Hi- I have tried e-mailing and pm-ing you and nothing- I am a cash customer! Can you try to contact me. Thanks, Steve
