Ignition switch panel
Mel King
First Name: Melvin
Last Name: King
Post by Mel King » Mon May 13, 2019 8:52 am
When did the switch changed from 4 rivit to 2 rivit ? :?: MEL
Re: Ignition switch panel
Post by Original Smith » Mon May 13, 2019 9:35 am
Pretty early on I'd guess, probably sometime in 19 or 20. You have to consider too that at least three or four companies made them, and they didn't all do their riveting the same way.
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Post by SurveyKing » Mon May 13, 2019 10:21 am
To piggy back on the initial question here, does anyone know if the lettering on the switch plate was painted white? I have seen them both ways.
Post by DanTreace » Mon May 13, 2019 10:48 am
Originals show paint in the stamped metal lettering.
1919 from illustration
1926 non-starter
1919 with large nickel handle
1919 style with paint.jpg (50.27 KiB) Viewed 2649 times
