Jern thunderbolt
Gen3AntiqueAuto
Last Name: Foye
* REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Jern thunderbolt
Post by Gen3AntiqueAuto » Thu Jun 15, 2023 4:28 pm
Anyone have a source for gaskets? Friend stopped in today hoping I had a set but no...
kmatt2
First Name: Kevin
Last Name: Matthiesen
Re: Jern thunderbolt
Post by kmatt2 » Thu Jun 15, 2023 4:50 pm
If you only need a stock Ford T and a stock Chevy 4 cy head gasket for each side of the adapter, then try , The Filling Station, in Lebanon OR. they sell vintage Chevrolet parts. Of course Lang’s has stock Model T Ford head gaskets. I don’t know enough about how the Jern adapter mounts on the T block to know for sure, but would think that is how the adapter was designed.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Jun 15, 2023 5:10 pm
Do you need both or just the top? There was an issue Neal and I addressed just before his death and it keeps them from blowing in the front. I do need a picture of the style you have as there were some changes.
Let me know.
Post by Scott_Conger » Thu Jun 15, 2023 5:48 pm
you are darn close to getting into the Model T hobby...
:lol:
Post by Mark Gregush » Thu Jun 15, 2023 7:05 pm
Olson's Gaskets should be able supply the one that goes between the adapter and head. The other one is just the standard overhead gasket sold by the parts suppliers.
While you could use the Chevrolet gasket, because of the design of the adapter, that would leave a gap between the plate and head in some locations. https://www.olsonsgaskets.com/
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Jun 15, 2023 8:50 pm
Neal's gasket was a work of art and in a clover design. An original Chevy gasket will work for a time but with his water neck adapter a no go. Did a lot over the years, just sayin'
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Fri Jun 16, 2023 11:18 am
Poor Mans Rajo - Gen III Antique Auto.pdf
(1.59 MiB) Downloaded 119 times
I'd cut one myself on the cnc but I am unsure of how to form the fire ring. Answering the question above = "not stock T or chevy".
Here's an archived page from my (now stolen) website from 2007 that shows the plate. I had gasket photos - haven't found them yet. If I remember right the bottom one has round holes and isolated the push rods. The top one is longer than a stock chevy due to the water outlet adapter.
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Fri Jun 16, 2023 11:39 am
You can see what one gasket looks like in this one.
Post by Mark Gregush » Fri Jun 16, 2023 11:44 am
I used one of Gene's water outlets, which had a larger footprint and bolted both to the adapter and head so was able to make my own gaskets to mount it. Forgot the Jern was mounted on the head then machined to same level, using the head bolts to hold in place. Using a stock Cheverolet gasket might still work if you can get that outlet to seal.
When I made my adapter, I went with round holes instead of the heart shaped ones like Jern's. Had to work with the plans I had and tools that were at hand.
Anyway, as I said, try contacting Olsons. https://www.olsonsgaskets.com/gaskets/f ... onversion/
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Jun 16, 2023 12:38 pm
My very last set! Only sold as a set.., $300.00 with shipping.
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Sat Jun 17, 2023 12:15 pm
Hank, can you get more made? Can you send me a high-res photo and some dimensions (I can put the data in a cnc file) - can you see how the fire rings were made? Rolled? thickness? I can't afford to buy them from you at the moment... I did send the info to the person that showed up here looking for a set - maybe he'll contact you. Not sure if he gets texts on his phone (tech-phobic guy). I'll follow up in a couple days.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Jun 17, 2023 1:30 pm
Unfortunately Tim I do not have any spare time with everything going on. Life gets in the way.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Jun 17, 2023 3:07 pm
FYI, Hanks offer seems generous to me. I rarely make solid copper gaskets these days as the prices of materials and labor has gone up considerably in the last several years. My latest cost for a solid .040” copper gasket was $200! I suggest snatching these up if you need em…
Post by Mark Gregush » Sat Jun 17, 2023 4:09 pm
Did you also send the information regarding Olsons Gasket?
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Sun Jun 18, 2023 3:02 pm
He already called them.
Post by Scott_Conger » Sun Jun 18, 2023 7:51 pm
one day out of the blue, someone asks: "Is there a rare thingy made of unobtanium available anywhere on the planet?"
a scant 30 minutes later, an answer miraculously appears from the ether: "yes, I have one and I'll sell it"
one day later after much futzing around: "never mind"
the fact that this gasket is still sitting in a garage atop a mountain in TN is tragically comical. I'll bet that the next time it sees the light of day, the finder will be shocked and eternally grateful. Time will tell...
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Thu Jul 13, 2023 3:34 pm
I passed the info on to the person looking - not much more I can do!
