BAITH WITH CAUTION...MOISTURE IN THE COIL BOX
Tom Donnelly
Last Name: Donnelly
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by Tom Donnelly » Fri Jun 16, 2023 7:13 pm
First thank you Joe Bell, better known as ‘Engine Joe’, for your help with the final diagnosis of my ’21 Touring electrical problem! Last Saturday, after spending almost a year out of commission, I decided to carefully wash it, wax it, and take it for a drive. After the wash, it would only run on #2 & #3, but all four coils were buzzing. I called Joe and his advice was to check and see if the spark advance rod or something was arcing to the #1 & #4 commutator posts. Instead, I discovered tiny sparks arcing to the coil box metal on both sides…from the wood! I took it apart and found that the arcing had created a thick path of pure carbon on the wood on both sides of the box (see below). A little rust staining on the wood might have also contributed. After sanding the wood, I further discovered black pin holes at the edge of the wood that extended through the wood to the #1 & #4 electrodes. After sanding, I cleaned out the pin holes and rubbed a heavy coat of silicone on the two edges of the panel followed by a wrap with two small strips of sheet-pvc over the wet silicone. The problem likely began after the bath with moisture getting into the coil box wood. Aside from having to do a sponge bath in the future, doe’s anyone make a plastic board assembly for the Coil Box?
Moxie26
Last Name: Jablonski
Re: BAITH WITH CAUTION...MOISTURE IN THE COIL BOX
Post by Moxie26 » Fri Jun 16, 2023 7:21 pm
Tom.... Bring up coil box parts on your supplier website, and there are plastic versions for your coil box. The condition you found is called " carbon tracking " . Be sure that you put your coils out in the Sun for them to dry out thoroughly and then follow with a coat or two of boiled linseed oil for further moisture protection.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Fri Jun 16, 2023 7:28 pm
Engine Joe has helped me and many others. He knows model t inside and out.
Art Mirtes
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Fri Jun 16, 2023 7:51 pm
I remember on a tour I was with had all the T's in the parking lot of the state park,it rained over night, and 1 guys coil box got soaked. If I remember correctly we took turns holding it under the hand dryer in the mens bathroom trying to get it dried out enough to run.
Post by TRDxB2 » Sat Jun 17, 2023 9:43 am
The suppliers sell a waterproof coil box board that was made by FunProjects. If the stock has been depleted & Birdhaven hasn't continued to supply them you can waterproof a wood board. As an example (there are many similar products & some use varnish as well) Products like Minwax below soak into the wood.
box coil.png (66.11 KiB) Viewed 3507 times
Post by Jerry VanOoteghem » Sat Jun 17, 2023 9:51 am
Thank you for posting your experiences and the photos! A lot of folks don't realize that the arcing can occur internally, between the layers of plywood.
Post by RajoRacer » Sat Jun 17, 2023 11:30 am
Snyder's has the plastic rebuild kits.
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Sat Jun 17, 2023 12:48 pm
Go to Google and search the following:
carbon track mtfca.com
I think that you will find out that the carbon tracking has been problem for a long time. Most Model T owners have been there, if not- it's coming! Thankfully, John Regan (Fun Projects), came up with a solution that works. His creation literally stops the problem.
Moxie26
Post by Moxie26 » Mon Jun 19, 2023 12:18 pm
Hey Tom ..... How's your coilbox rebuilding progress coming along?
Post by Steve Jelf » Mon Jun 19, 2023 2:15 pm
John Regan's Fun projects kit:
Tom Donnelly
Last Name: Donnelly
Post by Tom Donnelly » Mon Jun 19, 2023 4:16 pm
A big thank you to all of you for your wisdom and comments! Thanks John for your initial comments on Carbon Tracking. I got it running on all four after the silicone and PVC.
Moxie26
Post by Moxie26 » Mon Jun 19, 2023 9:29 pm
What you have there is a newer wood coil box replacement..... you should really reconsider getting the non-conductive plastic panel sections so that your past problem does not repeat itself. If you consider using the wood coilbox panels, they should be coated with at least three layers of boiled linseed oil before any hardware is attached to the wood. The boiled linseed oil will seal out any entrance of moisture into the wood for a given time period of a few years when used on the coil box wood and plus the four individual coils.
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Tue Jun 20, 2023 6:32 am
One can also utilize this unique Casco accessory to keep the water out... have this on my T, and although hidden, it gets the job done woth shield and rubber grommets.
Dennis_Brown
Last Name: Brown
Post by Dennis_Brown » Tue Jun 20, 2023 10:05 pm
I am not sure how thick the wood is that is used on the coil boxes without going to the garage tonight. Could a person make a replacement from white plastic cutting boards used in the kitchen? The ones we use are 320 thousandths thick and they would not build up carbon tracks. If it would work and you did not want the white to show you could use a dark brown stain on it.
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Wed Jun 21, 2023 10:08 pm
Interesting and timely too! Excellent thread! Glad you're running again Tom.
That Casco is very cool Andrew.
Preservatives for wood: A little off topic. Would Flood's Penetrol work as well as Minwax wood hardener? For coil wood.
The '18 here had his coil box rebuilt in the mid-late 70's with a plywood kit. So far it's been OK but have a Regan-Fun kit stashed.
