ACCESSORY STEERIN GEAR
Liberty Garage
Topic author - Posts: 84
- First Name: Steven
- Last Name: Nelson
- * REQUIRED* Type and Year of Model Ts owned: 2 speedsters, 24 touring,19 pickup
Model T accessory steering gear. Mounts in the same position as the original steering mount. $400 + ship
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
Re: ACCESSORY STEERIN GEAR
What is it exactly?…..original type?
Liberty Garage
- Last Name: Nelson
No name on it. Planetary gears in the housing
blauvelt
- First Name: Douglas
- Last Name: Ogden
If anyone does know, I have the same one. It is light weight, was thinking it is off a cycle car, or something around that size.
- First Name: craig
- Last Name: leach
To the best of my knowlege that is a accessory steering system for model T. I believe it was designed to have a better ratio to make steering
easier & prevent steering whip in revearse. There should be a coupling to the T shaft & a device to eliminate the gears in the column. A online
search may shed more light on the part. I have seen them sell for about that amount before. So in todays market that should be a good price.
Might be somewhat like this T accessory steering gear?, seems very similar. But didn’t see the T spark and throttle rod guides in that casting like this one has.
