Hi all,
I just noticed that the fan is contacting the front wiring harness which is not attached to anything. Can some one please tell me or show me a photo of the route of this wiring harness goes? What does it connect to/clip to, go over/under so that it won't be in the way of the fan.
Thanks so much,
John
fan cutting front wire harness
Re: fan cutting front wire harness
New radiators come with attached sheet metal strips to hold the hasness @ the tank edge.
I run the harness under the pan snout on my T's that dont have those clips.
need to clarify if it is the lighting loom or the timer wiring
