FS - left side mount belt drive alternator
Topic author - Posts: 174
- Last Name: Bruto
- * REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
New 12 volt alternator kit for 09-27 for model T. Simple bolt on installation, no modifications to engine required. Mounts on the left water outlet neck bolt using a special included bolt, tension bracket uses two of the block to pan bolts. 12 volt, 30 amp, negative ground mini Denso style alternator has a flat belt pulley. Requires a longer belt (not included). 2 wire hook up - positive to ammeter, ignition on switched positive.
- First Name: Raymond
- Last Name: Emling
- * REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo, 1914 roadster, building:1910 roadster, 1911 touring
Re: FS - left side mount belt drive alternator
Is this your design. I am interested.thanks ray
- Last Name: Bruto
It is, I needed something on my speedster so I came up with this.
Nice design - was also wondering the same !
- First Name: Neil
- Last Name: Dobson
- * REQUIRED* Type and Year of Model Ts owned: 5
Hi Mark, I would be keen to purchase one - are you able to ship internationally to New Zealand.
- First Name: Mario
- Last Name: Brossard
Hi Mark, Interested to get one for my speedster either. I have USA address as well. mario dot brossard at sympatico dot ca
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- Last Name: Bruto
back to the top
- First Name: Ervin
- Last Name: Mims
- * REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
I too, would be interested in one or two of them email address EWM 1948@yahoo.com or phone 512-995-6013 Wayne Mims
- Last Name: Seress
Birdhaven sells the complete setup, no brainer installation. Just thinking out loud.
- Last Name: Bruto
This is also a no brainer install and does not use head bolts for mounting, plus the alternator is smaller than the delco unit. The only part not in the kit is a longer belt. Just explaining out loud.
- First Name: Randall
- Last Name: Strickland
Heres the same I came up with 7-8 years ago!
- Last Name: Bruto
Great minds think alike!
6 volt version in the works.
- Last Name: Bruto
back to the top
- Last Name: Bruto
6 volt version now available. https://www.ebay.com/itm/266502857774
- First Name: Will
- Last Name: Snyders
- * REQUIRED* Type and Year of Model Ts owned: 1915 Roadster Pickup
Ordered 12 volt version from EBay, very good price
Excellent product and mounting hardware, simple to install
It is a 2 wire compact alternator, one wire for battery positive, one for switch on position
For my 1915 needed a 34” belt.
