Timer... "Ain't Nobody Got Time for That."
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sat Jul 01, 2023 8:39 am
So, I purchased some parts from the vendors for the day timer with a bushing.
I greased the felt to help stop leaking?
The pin would not go into camshaft hole unless I screwed down the nut some.
When I turned the hand crank, things started looking bad.
Is the felt the wrong size?
Vern (Vieux Carre)
Last Name: van Ekeren
Re: Timer... "Ain't Nobody Got Time for That."
Post by Kerry » Sat Jul 01, 2023 8:42 am
Your cam nut is fitted with a modern seal, forget about the felt and the disc.
Last Name: House
Post by George House » Sat Jul 01, 2023 8:51 am
I agree…..
Post by Scott_Conger » Sat Jul 01, 2023 9:01 am
Hopefully the modern seal is not crushed or otherwise distorted now
Post by John kuehn » Sat Jul 01, 2023 9:06 am
You mentioned in your first post that the felt was installed to help stop leaking. Was it leaking? If it was leaking the seal needs replacing.
Since you have a modern seal installed it takes the place of the felt and felt cover.
Post by Steve Jelf » Sat Jul 01, 2023 9:13 am
Yes, ditch the felt and disk. If the seal is leaking, replace it with a new one installed with Ultra Black or other good sealant behind it. It won't hurt to put a little grease on the shaft to help the new seal slide into place.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sat Jul 01, 2023 9:46 am
...leaking in general.
This is a new seal and I obviously don't know what I'm doing. Felt removed.
Thanks guys.
Vern
Vern (Vieux Carre)
Post by Scott_Conger » Sat Jul 01, 2023 9:50 am
It's how you learn, Vernon
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sat Jul 01, 2023 10:01 am
If it doesn't leak, you've just ran out of oil
Post by TRDxB2 » Sat Jul 01, 2023 10:15 am
The difference between knowledge & wisdom.
knowledge acts, information, and skills acquired by a person through experience or education; the theoretical or practical understanding of a subject.
wisdom the soundness of an action or decision with regard to the application of experience, knowledge, and good judgment.
In other words, having the additional knowledge of what not to do
You are a bit wiser now
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sat Jul 01, 2023 11:16 am
Thanks for replies.
Yes, it ran out of oil. Hope to put some in there this year... for the first time.
I will continue to role play and dispense lack of wisdom on here so that your great knowledge application can be recorded for future generations.
Vern (Vieux Carre)
Post by Jerry VanOoteghem » Sat Jul 01, 2023 12:27 pm
Vern,
Check your oil every time you get gas. (Gasoline, that is! :roll: )
Post by John kuehn » Sat Jul 01, 2023 1:51 pm
Hey Varmint!
This is how we learn about the old ‘100 year old technology’ cars. T’s were meant to have maintenance checks pretty often more than we are use to with our newer cars. People didn’t drive as far or long as we do now.
We all learn things about T’s from time to time. A 100 mile trip in a T can be compared to a 500-1000 mile trip today. Good luck with your T and have fun driving it! Checking the oil and routine cleaning of the timer people got use to doing since it was something that Ford recommended be done.
As far as leaking goes Fords new T’s in showrooms had pans or sheets of material to catch occasional oil drips. It’s just the way they were.
Last Name: Wrenn
Post by TWrenn » Sat Jul 01, 2023 2:03 pm
Just remember..."old age and treachery shall overcome youth and skill"! :lol:
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sat Jul 01, 2023 2:06 pm
We are talking about timers and oil, however...
Our "New Day Timer" says "no oiling".
I'm assuming that is still true by today's standards.
Vern (Vieux Carre)
Last Name: Wrenn
Post by TWrenn » Sat Jul 01, 2023 2:16 pm
YES! Oil is a carbon brushes worst enemy. Just keep it clean..I still love and prefer my TW timers but they too need cleaned every oil change. No big deal to do it and I've never had a car run so smooth.
Post by John kuehn » Sat Jul 01, 2023 4:02 pm
Just another maintenance item. The original roller timers were good but eventually made a mess after a while because of the oiling maintenance that came with them. They had an oil access cap on them. Over time if you didn’t clean up the area it got pretty grimy and dirty.
The New Day was an improvement in that area because it didn’t need excessive routine oiling and only a little cleaning like yours. Now days WD40 will clean them up pretty well or using fine sandpaper to lightly and evenly sand them. Steve Jelf has a forum post how to clean one up if it needs more attention than yours.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sat Jul 01, 2023 5:03 pm
Jerry,
I have no idea how it got so clean. Just handed to the wife and that's the way I got it back, with screws in place. She threw away the old steel ones.
Vern
Vern (Vieux Carre)
Post by John kuehn » Sat Jul 01, 2023 6:01 pm
I’ll bet she may have used an S O S pad. With the soap that’s in them and the fine steel wool they make a great cleaning and polishing pad.
