Where does the air pump go?
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Sat Jul 01, 2023 10:23 pm
I have been looking at original air pumps for the T, but I am not sure where I would put it on my 22 RPU. If it had the turtle deck it would go there. If it was a touring car, it could go under the back seat. Did they make a mount for these that I could put somewhere on the bed?
Re: Where does the air pump go?
Post by Steve Jelf » Sun Jul 02, 2023 1:19 am
Running board tool box, if you can find one more than 22" long. My box is 22", and the Ford pump almost fits in it.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sun Jul 02, 2023 2:09 am
We might have the same tool box. Mine is 22 inches as well.
Post by Jerry VanOoteghem » Sun Jul 02, 2023 8:42 am
I believe in my '21 Roadster it's sitting behind the gas tank, under the seat.
Post by Allan » Sun Jul 02, 2023 8:59 am
A nicely made wooden running board toolbox can be made to the required dimensions, and mounted to the running board with the same bolts as the running board, so you don't even have to drill holes.
Post by Original Smith » Tue Jul 04, 2023 12:39 pm
Ford introduced a behind the gas tank tool box in mid year 1925 for the roadster models. It has plenty of room for a tire pump.
Post by TRDxB2 » Tue Jul 04, 2023 2:09 pm
This one can go anywhere. Approximate dimensions when folded: length is 13.5 inches x 4.5 inches at widest point. Coiling a hose dimensions?
viewtopic.php?f=5&t=29579&p=228233#p228233
