Flathead V8 in a T Speedster
Professor Fate
Last Name: S
Post by Professor Fate » Tue Jul 04, 2023 1:33 am
________________
**FATE**
Professor Fate
Last Name: S
Re: Flathead V8 in a T Speedster
Post by Professor Fate » Tue Jul 04, 2023 7:05 am
Does anyone know this car?
________________
**FATE**
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Jul 04, 2023 8:03 am
Do not know the car but with those bent angled front wishbones with no bracing or caster back...., better have good life insurance. The weight distribution is a little too far back so the steering would be like steering a loaded truck. Building cars that look cool but handle well is a science with disciplines in automotive technology. Just sayin'
Art M
First Name: Art
Last Name: Mirtes
Re: lathead V8 in a T Speedster
Post by Art M » Tue Jul 04, 2023 8:45 am
The wishbones could possibly control body roll rate.
This is controlled by stabilizer bars (roll bars) in modern cars.
Henry is right, an experienced chassis engineer is needed. I was a chassis engineer for many years and was a stabilizer bar engineer for several years.
Art Mirtes
John Codman
Last Name: Codman
Post by John Codman » Tue Jul 04, 2023 9:37 am
The front end of that car is scary!
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Tue Jul 04, 2023 10:35 am
Terrible driver's compartment geometry - dangerous lack of leg room and steering wheel too close to the driver.
Should move the seat back and lower the steering column.
Post by John kuehn » Tue Jul 04, 2023 11:26 am
This little speedster is made to look at in somebody’s old car collection.
I don’t think I would run down the road in it over 50 mph even though that flathead Ford could probably get close to a 100 with the light body. And doing 50 would be running straight and no tight curves.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Jul 04, 2023 12:25 pm
Look again fellas… that’s a V8-60! Not exactly a performance improvement, even for a T
Post by Rich Eagle » Tue Jul 04, 2023 12:39 pm
That is what I should do with my '35. I can't seem to get any work on it and that might be simpler.
It is nice execution of design and very well done.
John Codman
Last Name: Codman
Post by John Codman » Tue Jul 04, 2023 1:35 pm
I was wondering about that. I have never personally seen a V8 60, but the flathead in that speedster looked small.
Post by TXGOAT2 » Tue Jul 04, 2023 1:36 pm
A V8 60 would work great in a T. You'd have enough HP and engine speed range to go pretty fast in a stock bodied T using the stock transmission and driveline. 60 HP up around 3600 RPM would move a T along quite nicely. The V8 60 doesn't have much low end torque, so the T driveline would stand up OK. Cooling might be a challenge.
Post by TXGOAT2 » Tue Jul 04, 2023 1:37 pm
There's a good deal of info on 60 HP V8s on the internet. Finding a good one would be a challenge. Cute little things...
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Tue Jul 04, 2023 1:47 pm
There was a 26/7 coupe at the canyonlands tour years ago. Used model A rear I think, like this speedster. As I understand it, crack free V8-60 blocks are getting hard to find.
Andy
John Codman
Last Name: Codman
Post by John Codman » Tue Jul 04, 2023 2:09 pm
Andy
That doesn't surprise me. There weren't all that many of them to begin with.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue Jul 04, 2023 5:12 pm
I'd say from 20 horse to 60 horse is quite an improvement, however as others have said, the car needs some re-engineering on the steering and front suspension. It appears to me this car could get someone in serious trouble, if its power and speed were not respected. It would be a great little ride if it didn't have safety issues. I won't bother to say anything about it being promoted as a 1917 with a brass radiator and what are probably 28-29 wire wheels, as the rear axle looked Model A or early V8 (certainly not T).
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Tue Jul 04, 2023 5:48 pm
Fate, that dumb song is stuck in my head now...
John iaccino
Last Name: Iaccino
Post by John iaccino » Tue Jul 04, 2023 6:14 pm
A friend of mine in New Jersey has a V8 60 in his 27 roadster. Goes like a raped ape.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue Jul 04, 2023 7:25 pm
Good lord. To be young and stupid again. I really miss those days…..
Professor Fate
Last Name: S
Post by Professor Fate » Tue Jul 04, 2023 8:38 pm
Glad others have seen what I saw, and more!
Please be safe out there!
Car is a nice one for display
________________
**FATE**
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Thu Jul 06, 2023 8:43 am
To sit in someone's front lobby as a lookey loo - perfect.
Do drive down the road with all the weird geometry going on - sorry, for me life is too precious to throw away.
My 2¢,,,
Professor Fate
Last Name: S
Post by Professor Fate » Thu Jul 06, 2023 9:51 am
Run those rear tires at low psi, and I bet you could spin those valve stems right off!
________________
**FATE**
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Thu Jul 06, 2023 3:17 pm
While this speedster can be picked apart for a number of reasons, the same could be said for almost any speedster. Speedsters are very personalized, you build what you want.
Andy
Post by Jerry VanOoteghem » Thu Jul 06, 2023 4:02 pm
Andy
Personalized is one thing, but dangerous is whole different thing. That thing is dangerous.
Post by Jerry VanOoteghem » Thu Jul 06, 2023 4:03 pm
Look at the sharp angles on the steering linkage. The last u-joint just sticking up there with no support whatsoever. Yikes!
Post by Scott_Conger » Thu Jul 06, 2023 4:39 pm
what you get when a high school art class student has a father with more money than sense and a shop that will build anything for a buck.
I can only imagine what it must be like having to operate the pedals with ballet slippers and pointed toes, and then lean forward to honk the horn to warn the guy who is about to cut you off. The whole thing is really too ridiculous for adequate words. This isn't just something that is an acquired taste, it is ridiculously proportioned for a cartoon character and is specifically designed to be a deathtrap.
Should bring big money.
Professor Fate
Last Name: S
Post by Professor Fate » Thu Jul 06, 2023 8:20 pm
Can't agree more with Mr. C
Maybe we can get the creepy video guy to destroy this car next, and maybe save a life or two in the process.
"....The whole thing is really too ridiculous for adequate words. This isn't just something that is an acquired taste, it is ridiculously proportioned for a cartoon character and is specifically designed to be a deathtrap."
Bravo Mr. C!
________________
**FATE**
