Doing things the hard way
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Thu Jul 13, 2023 6:48 pm
Looking for knowledgeable suggestions. The timing gear cover on my '13 (and I presume on all previous Ts) presents a difficulty for the camshaft seal. Rather than having a rebate and using a shield plate like the later cars, the cover has a "pocket" which is meant to carry a felt "donut". I made a "seal" from felt I had available when I changed the timing gear a few years back, but it wasn't particularly successful. If others have solutions for this, I'd be very grateful to learn how you managed it. I'm suspicious the felt sheet i used to form the seal may nit have been of a proper density, and it's hard to cut felt accurately.
Yes, I know I can machine the cover to accept a modern seal, or swap it for a later cover, but I'm loth to go that route. It would probably result in my being ejected from the Purists and Brass Snobs Club. :lol:
Get a horse !
michaelb2296
First Name: Michael
Last Name: Bunner
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Re: Doing things the hard way
Post by michaelb2296 » Thu Jul 13, 2023 7:45 pm
I wonder, if you took the felt (filler), a nylon washer for strength and the modern neoprene washer (removed from the 1915-1916 type casing) and glued it to the nylon washer and shoved it all inside of that donut hole whether or not it would work similarly to the national seal used in the 1915-1916 type castings???? Just a thought.I know the national seal will fit the opening exactly (with the spring on it) but without more backing it won't work.
michaelb2296
First Name: Michael
Last Name: Bunner
Post by michaelb2296 » Thu Jul 13, 2023 7:52 pm
oh look.... it's already been done: https://www.mtfca.com/discus/messages/8 ... 1533316469
They took the modern seal, smashed it flat and glued it to the front.
michaelb2296
First Name: Michael
Last Name: Bunner
Post by michaelb2296 » Thu Jul 13, 2023 7:54 pm
national part # 471224. but, they also mentioned some other seals ...
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Thu Jul 13, 2023 8:10 pm
I made one for our 1911 engine. I used a 1/4" (I believe) nylon rope cut to fill in the groove. I coated it with RTV all around and with the camshaft covered with Saran wrap, I centered and bolted the cover on. After curing, I removed the cover and Saran wrap and reinstalled the cover. Seems to have worked well and no leaks!
Neal
Post by Allan » Thu Jul 13, 2023 8:23 pm
If a 1913 cover has the deeper oil filler recess, there are later model covers which have the open seal land.and the deeper filler. The duck's guts are the last of them with the larger crankshaft seal groove which will take the A model white rope seal material. That saves any modifications to original T parts.
michaelb2296
First Name: Michael
Last Name: Bunner
Post by michaelb2296 » Thu Jul 13, 2023 9:09 pm
Neal,
I like it! Sounds like the way to go... Give it 24hrs and you're done!
Michael
RVA23T
Last Name: C
Post by RVA23T » Fri Jul 14, 2023 12:41 am
You can also find Teflon wahsers instead of nylon.
McMaster Carr has them.
I view nylon as too "abrasive" to use in a rotating location and Teflon can take high heat.
michaelb2296
First Name: Michael
Last Name: Bunner
Post by michaelb2296 » Fri Jul 14, 2023 10:55 am
Post by Allan » Sat Jul 15, 2023 11:28 am
From my memory, 1/4" wide packing would be extremely difficult to pack into the narrow groove in the cover. Plus, making a seal at the joint would be just as difficult.
That type of seal works well on the front crankshaft seal between the block and the pan because each end of each half cab be left a little proud so that there is some crush between the two. I can't see that happening in a timing cover.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sat Jul 15, 2023 12:25 pm
Good thoughts here worth considering. I don't suppose anyone knows for sure what the original seal was? I believe (from looking at the parts list) it was a felt "donut". Perhaps the answer lies in using the correct density of felt, and an accurate way to cut the donut. More study is indicated ! :lol:
Get a horse !
Post by Rich Eagle » Sat Jul 15, 2023 12:38 pm
I presume you are using a New Day or other brush type timer. Thus, no oil wanted.
With roller timers, I always wondered about the necessity of sealing out engine oil and then oiling it through the flip top oiler. That seemed to be an exercise in futility. :lol:
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sat Jul 15, 2023 2:14 pm
My thoughts too, Rich. A little "bleed" past the cam seal is good for a roller timer I'm sure. I'm running a TW, which has forgiven the lack of a better seal, but it probably would be happier with a drier environment.
Get a horse !
