NEW 12 tooth pinion thank you Chaffin’s
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Fri Jul 14, 2023 10:38 am
The vendor contacted us & has them in stock. Thanks Mark & Dave at Chaffin’s Garage!
Thanks John
Re: Any one have a NEW or very good used 12 tooth pinion they’d sell?
Post by speedytinc » Fri Jul 14, 2023 11:04 am
Did he contact Chaffins? They had a barrel full.
Post by JTT3 » Fri Jul 14, 2023 7:44 pm
Dave said they were out
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sat Jul 15, 2023 10:58 am
Yes, Chaffin's is the manufacturer. The would be buyer needs to contact them.
Post by JTT3 » Sat Jul 15, 2023 1:55 pm
I’ve contacted Chaffins they are out right now. Still looking!
Post by JTT3 » Sun Jul 16, 2023 3:47 pm
Back to the top
Post by JTT3 » Thu Jul 27, 2023 8:59 pm
Bump to the top
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Fri Jul 28, 2023 3:40 pm
We just obtained a small batch of 12 tooth pinions from our gear cutter. Only took us over a year to get them. Whole supplies last. Thank you.
NoelChico
First Name: Noel
Last Name: Chicoine
Re: NEW 12 tooth pinion thank you Chaffin’s
Post by NoelChico » Fri Jul 28, 2023 4:38 pm
You may need to shim a Ruckstell or recessed ring gear as I don't believe any were made to accept a 12 tooth that is smaller diameter than a 13 and bigger than an 11 tooth. I made a large ring gear shim from a 1/16 sheet of aluminum to get my ring-pinion clearance. Stacking 4-5 thinner shims may be asking for sheared ring gear bolts.
Post by Wayne Sheldon » Sat Jul 29, 2023 6:13 am
Personally, I would not trust aluminum for that type of a shim. It has enough "give" that it could lead to shearing the bolts. I have seen other places where aluminum was tried for shimming to fit, and seen it fail. I have not seen it used for a ring gear, but it makes sense to me that it might not be tough enough. The ring gear takes a lot of beating from driven torque and braking, that anything that allows any "give" at all would likely lead to failure.
My opinion.
