TT Ton Truck Remove rear springs from frame
chippy74@bigpond.com
First Name: Matthew
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 19## TT ton truck, 19## T Pickup
Post by chippy74@bigpond.com » Wed May 15, 2019 10:03 pm
Good morning,
I’m attempting to remove the springs from the rear of a TT Ton Truck and have removed the six 1-1/16 crown head nuts from there bolts, the triangular plates and the two U shaped shackles but have not been able to remove the bolts from the frame that run through from the end of each set of leaf springs.
Are they threaded in, are they pressed or maybe just extremely seized?
Any help greatly appreciated.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: TT Ton Truck Remove rear springs from frame
Post by D Stroud » Wed May 15, 2019 10:15 pm
Mathew, they are most likely rusted in tight. They can be a real bear sometimes. Then, the springs will be rusted in pretty tight probably. Dave
1925 mostly original coupe.
First Name: Matthew
Last Name: Brown
Post by chippy74@bigpond.com » Wed May 15, 2019 10:22 pm
Thanks Dave I’ll keep working the mongrels.
Post by Steve Jelf » Wed May 15, 2019 10:34 pm
Don't be surprised if you find one or more of the smallest spring leaves broken. Those trucks were often overloaded, so there are a lot of broken leaves.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Wed May 15, 2019 11:38 pm
I found I had to remove the clamp from the spring pack then chisel each leaf off one at a time....
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Thu May 16, 2019 1:04 am
When you tear into these darn old trucks you never know what you're going to find. When I took mine apart I found one top leaf broken and one missing altogether. What was really interesting was the fact that on the left side the pin bolt went through the top and bottom leaves but the rest were just stuck in there loose, with the bolt not passed through the leaf holes. I can't imagine what kept them from falling out. I'd sure like to know the story behind how that came to be.
Good luck with yours!
First Name: Matthew
Last Name: Brown
Post by chippy74@bigpond.com » Thu May 16, 2019 2:46 am
Finally got them out, it was a battle but all the springs are in reasonable condition.
Thank you all for your replies.
