Soft brakes
JBog
First Name: Jason
Last Name: Bogstie
Soft brakes
Post by JBog » Sat Jul 29, 2023 1:10 pm
In the midst of parade season. I noticed when driving to the parade my brakes are crisp and work fine, by the end of the parade, the brakes feel really soft and I ended up using the hand brake a few times. What could be the problem or is that normal?
I am running Rocky Mountain Brakes in addition to the standard equipment.
Re: Soft brakes
Post by RajoRacer » Sat Jul 29, 2023 1:21 pm
Sounds as though an "adjustment" is in order.
Art M
First Name: Art
Last Name: Mirtes
Re: Soft brakes
Post by Art M » Sat Jul 29, 2023 1:36 pm
What is the type of lining.
Art Mirtes
Re: Soft brakes
Post by TXGOAT2 » Sat Jul 29, 2023 1:41 pm
Frequent use of the brakes may cause the bands to heat up, expand, and loosen slightly.
As long as you have a reasonable aount of pedal reserve above the floor board, you should be OK.
Tightening the adjustments may help pedal feel, but overtightening will cause problems.
Be careful not to "ride" or drag the brakes, which will cause rapid heat build-up. Be sure the pedal and all brake linkage releases fully when you take your foot off the brake.
Be sure brakes are not adjusted too tight, which will also cause excess heat build-up.
Re: Soft brakes
Post by Norman Kling » Sat Jul 29, 2023 1:51 pm
I don't know whether or not you have Ruckstell or other auxiliary transmission? But if you do, you can do as I do and put the transmission in a lower range and pull the parking brake lever to the neutral position. Then wait until the unit in front of you moves up a bit and then tap the low pedal. Let it coast in neutral as far as it will and then tap the pedal again. Only use the brake if you need to stop before you hit someone in front of you. Also weaving back and forth along the route if you have room to do so helps. Anyway, I also have Ford transmission brakes and Rock mountain brakes on my cars and have had no problems.
JBog
First Name: Jason
Last Name: Bogstie
Re: Soft brakes
Post by JBog » Sat Jul 29, 2023 3:16 pm
Art Mirtes
Wood
Moxie26
Last Name: Jablonski
Re: Soft brakes
Post by Moxie26 » Sat Jul 29, 2023 3:21 pm
I would tend to believe the metal bands are expanding from the heat given the effect of a lower pedal, regardless of what liner is used
First Name: craig
Last Name: leach
Re: Soft brakes
Post by Craig Leach » Sat Jul 29, 2023 3:41 pm
Hi Jason,
Start with Steves suggestion & work your way down they are all very valid ideas. I do many parades in the fire truck and don't remember ever
having that issue. I use the under drive low peddle & coast method & find it works well. I'm looking forward to the next parade as I just
replaced the Muncie with one with reverse in it & installed a 10 tooth pinion. Reverse Muncie & Ford reverse is super low forward.
JohnM
Last Name: Michaelree
Board Member Since: 2010
Re: Soft brakes
Post by JohnM » Sat Jul 29, 2023 4:54 pm
Check the brakes for grease leaking from a failed axle seal.
JBog
First Name: Jason
Last Name: Bogstie
Re: Soft brakes
Post by JBog » Sat Jul 29, 2023 10:20 pm
Thanks, everyone! Ill check it out
Last Name: Wrenn
Re: Soft brakes
Post by TWrenn » Sun Jul 30, 2023 7:04 am
He'd have to have a LOT of grease leajing out in order to "get up outside" on the RM's I would think. They do get themselves out of adjustment with that "knob" on top of the threaded rod adjuster. Also need to adjust the clevis on the rods as the shoe linings wear. I found that to make a BIG difference.
JohnM
Re: Soft brakes
Post by JohnM » Sun Jul 30, 2023 8:59 am
Happened to me. If you regularly pack the grease cups, or worse use a grease gun, the excess is pushed out and drops down on the inside of the drum. When driving, the centrifugal force flings it out between the drum and backing plate. I am not convinced this is the problem, but a two minute check will rule it out before spending more time making unnecessary adjustments looking for the problem elsewhere.
Last Name: Wrenn
Re: Soft brakes
Post by TWrenn » Sun Jul 30, 2023 11:13 am
Yeh but how is grease gonna make its way up to the top outside of the RM drum, especially since it's essentially totally covered by the break shoe anyway?
I say it's an adjustment issue. I've had mine do that similarly on long tours where the route required a lot of braking. That "top adjustment nut" is not very secured...it only uses a small detent to stay in place.
JohnM
Re: Soft brakes
Post by JohnM » Sun Jul 30, 2023 11:33 am
I have a 26 with large drum rockies, if grease leaks out between the drum and backing plate it will immediately get on the brake pad. Tim, I am not suggesting you are wrong, just offering a tip based on my experience.
