Identifying Timer Rotor
Dennis_Brown
Last Name: Brown
Post by Dennis_Brown » Tue Aug 01, 2023 12:21 pm
What type of Rotor is this?
Timer linkage installation, does the linkage go into the timer from the front with the cotter key toward the block or come in from the back with the cotter key on the radiator side? I am making new linkage that goes under the radiator lower hose. The old linkage that was on it from 50 years ago was too short, so the timer was turned farther to the left and # 1 coil wire had to be where #2 wire would normally be.
Dennis_Brown
Last Name: Brown
Re: Identifying Timer Rotor
Post by Dennis_Brown » Tue Aug 01, 2023 12:26 pm
Forgot the picture.
Post by Norman Kling » Tue Aug 01, 2023 1:11 pm
The linkage should be bent so that it goes below the lower hose and then curves up and over the top of the timer. All the rods I have seen have the linkage going behind the timer with the cotter pin in front. The rod must be behind the fan belt.
Post by speedytinc » Tue Aug 01, 2023 1:17 pm
The brush is an aftermarket replacement to replace the roller brush in a roller type timer.
Heres a view of the adjustable linkage I built.
The other end of the rod looks like the original rod.
Adjustable timer linkage
Moxie26
Last Name: Jablonski
Post by Moxie26 » Tue Aug 01, 2023 1:36 pm
Dennis.. just break out the pennies and order a rod from one of our suppliers..... That brush is not from a Ford comutator, it is an aftermarket with a different interior design. The standard timing comutator setting tool can only be used with a Ford comutator, nothing else. Follow the manufacturers instructions for setting your comutator. ..... Whatever timing rod you use , the length is determined by the comutator for basic timing at full retard lever position.
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Tue Aug 01, 2023 1:52 pm
It looks like the Splitdorf l, had quite a few they were for the T's
Last Name: Hatch
Post by Dan Hatch » Tue Aug 01, 2023 3:15 pm
Here is an NOS ONE.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Tue Aug 01, 2023 6:47 pm
Speedy,
Your adjustable linkage looks great. Can you describe the turning feature between the arm and the shaft.
Thanks in advance.
Art Mirtes
Post by speedytinc » Tue Aug 01, 2023 7:14 pm
Speedy,
Thanks in advance.
Art Mirtes
The magic piece is 1/2" round stock turned to fit the spark lever. (like a modern carb linkage fitting)
The rod goes thru the 1/2" body. The rod is locked in place with a square headed set screw.
It that what you wanted to know? Hope that helps.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Thu Aug 03, 2023 2:11 am
Speedy, you answered my question. It looks great.
Art Mirtes
