Water neck
Paradise Garage
Last Name: Howie
* REQUIRED* Type and Year of Model Ts owned: 1924 coupe
Water neck
Post by Paradise Garage » Thu Aug 03, 2023 7:18 pm
Is there a close substitute for a water neck (thermostat housing) that is common to another vehicle that I could make work on my model t?
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Water neck
Post by Humblej » Thu Aug 03, 2023 8:32 pm
No, there is not a close substitute, you will need a Ford water outlet, and a model T does not use a thermostat.
Re: Water neck
Post by TRDxB2 » Thu Aug 03, 2023 8:58 pm
What year?
First Name: craig
Last Name: leach
Re: Water neck
Post by Craig Leach » Thu Aug 03, 2023 9:20 pm
Hi Robert,
Are you looking for a elbow that is reccessed for a thermostat? Speedway Motors & other suppliers have a 45* swivel outlet for skinny block
chebies, I believe the bolt patern is the same (someone used a gasket from one on a T the other day.) It can be turned in any direction & locks
when tightened. I think you have to slip a short piece of hose on it to get the T hose to fit. I'm pretty sure some of the venders sell a thermostat
with a special gasket for that.
Re: Water neck
Post by Mark Gregush » Thu Aug 03, 2023 10:10 pm
The thermostat sold by the dealers is made to between the water outlet and head.
Jeff Hood
First Name: Jeff
Last Name: Hood
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
Re: Water neck
Post by Jeff Hood » Fri Aug 04, 2023 12:23 pm
I needed one in a pinch one time and used one for a small block chevy. You have to oval out the bolt holes, but it works. Different years and models have different angles. I believe the one I used was for a 1955, so even that might be hard to find. I just checked my parts stash, it was a Four Seasons 84820. The angle was good, but the hose size was smaller so I had to use another piece of hose as a sleeve, and oval the bolt holes.
Re: Water neck
Post by Allan » Sat Aug 05, 2023 7:32 pm
From sunny South Australia where we have California type climate, can I ask,"What is the need for a Thermostat'?' If it is to restrict the water flow to make the car run warmer,there were period accessories to blank off portions of the radiator, as seen in the latest of Tom Rootlieb's selection of photos.
