Hi all,
I have the wood framework installed on the Tudor. Is it easier to install the headliner with the wood on or off the car? I can do either way at this point. Thanks for any suggestions or experience you could offer. John
27 Tudor headliner question
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: 27 Tudor headliner question
Easier with the top bows on and the slats off. The headliner is then installed from the top. After the headliner is installed you can put on the slats and the top material. Some good older posts on this with pictures if you can find them.
NY John T
Topic author - Posts: 443
- Last Name: Killelea
Top bows and slats are all fixed in place
