U-joint problem on 1922 Canadian touring
Robt
Last Name: Mccullough
Post by Robt » Wed Aug 09, 2023 10:31 am
Rebult rear end with new thrust washers,
Drive shaft, bushing and u-joint. U-joint wouldn't go in the transmission. The new U-joint measured. 880, the Canadian u-joint measured 875. Anyone else have this problem?
Re: U-joint problem on 1922 Canadian touring
Post by speedytinc » Wed Aug 09, 2023 10:42 am
Repop U-joint.
Measure the square hole in the output shaft.
It may be there isnt enough chamfer in the corner edges of the new unit. Seen this before. Reparable with some grinding.
Better yet, dont fight a repop part, get a good original.
Last Name: van Ekeren
Post by Kerry » Wed Aug 09, 2023 5:46 pm
There was a bad batch of uni's made some several years ago that do exactly what you describe, you may have old stock or let's hope that new ones aren't made with the same mistake.
Post by Scott_Conger » Wed Aug 09, 2023 9:52 pm
Well, this last post proves that it will be at least a few more months before Cyberdyne finishes us all off...
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Aug 09, 2023 10:09 pm
Scott:
Everyone but the Amish.
