Transmission band springs
T. R. Quick
Last Name: Quick
Post by T. R. Quick » Sat Aug 12, 2023 8:47 am
Are there shorter tension springs that I could use to get more life from the band linings, specifically the low speed ?
Fordor forever
Last Name: Wrenn
Re: Transmission band springs
Post by TWrenn » Sat Aug 12, 2023 8:52 am
All I can tell you is if you're using Kevlar they require longer springs.
T. R. Quick
Last Name: Quick
Post by T. R. Quick » Sat Aug 12, 2023 8:59 am
I’m using woven cotton linings
Fordor forever
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sat Aug 12, 2023 9:20 am
Short or older band springs will not separate the bands from the drum after application and will promote lining where from not being released from the spring tension. And if the band adjustment nut is loose thinking that the band will release will probably promote the adjustment nut and lock washer to loosen and fall into the transmission and just promote engine problems. Using the new band springs with a greater release tension will promote better band adjustment on the linings.
Moxie26
Post by Moxie26 » Sat Aug 12, 2023 9:22 am
Short or older band springs will not separate the bands from the drum after application and will promote lining wear from not being released from the spring tension. And if the band adjustment nut is loose thinking that the band will release will probably promote the adjustment nut and lock washer to loosen and fall into the transmission and just promote engine problems. Using the new band springs with a greater release tension will promote better band adjustment on the linings.
T. R. Quick
Last Name: Quick
Post by T. R. Quick » Sat Aug 12, 2023 9:42 am
Thanks for the great reply!
Fordor forever
Post by Allan » Sun Aug 13, 2023 8:37 am
Tom, I'm a bit puzzled by your question. If your band springs are not allowing you to adjust the bands any further, are they coilbound? If so, the band linings/drums are well worn. Further adjustment may well result in the rivets coming into contact with the drum and scoring it.
