What is it worth?
Sarikatime
Last Name: Seress
What is it worth?
Post by Sarikatime » Tue Aug 15, 2023 7:27 pm
I have a 21 touring body on my 15 that I want to remove because I want a different stile body.
The body has a so-so paint job, new seat upholstery, front and back, new two man top with repaired bows and safety glass windshield.
New tack rail wood, corners and some of the wood replaced in the body prior to upholstery.
No cowl lights or tail lights.
Rear view mirrors on each side and in the middle of the windshield.
Looks real nice from 20 feet away.
All you have to do is bolt it down on your frame and you have a nice touring driver.
WHAT WOULD YOU CONSIDER THIS SETUP TO BE WORTH?
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: What is it worth?
Post by Humblej » Tue Aug 15, 2023 8:53 pm
$4000 to the right buyer.
RGould1910
Last Name: Gould
Post by RGould1910 » Tue Aug 15, 2023 8:58 pm
I'd start at $5000
RGould1910
Last Name: Gould
I'd start at $5000
Post by Scott_Conger » Tue Aug 15, 2023 8:59 pm
Jeff
I think that is a great estimate...and for the fellow who just bought a car with the bottom 6" missing and wants a "project", take it from someone who spent too much time saving too little history and jump at this opportunity if it presents itself to you...
jiminbartow
Last Name: Patrick
Post by jiminbartow » Tue Aug 15, 2023 9:18 pm
Depends on the condition of the underlying wood frame. If the wood is rotted, and the body is out of alignment, it won’t be worth much. Jim Patrick
