Where to purchase valve seat cutter
Dave_Kriegel
First Name: David
Last Name: Kriegel
* REQUIRED* Type and Year of Model Ts owned: 1927 1926
Post by Dave_Kriegel » Fri May 17, 2019 11:48 am
Well after 3 weeks good cylinders, good rings, good clean fuel, good spark now to get compression so the engine will start. Valves need redone Did 300 revolutions with grinding compound on number one cylinder decided need to regrind a good block seal face and buy new valves and springs The problem is where to buy a tool to resurface the block valve face ????
Re: Where to purchase valve seat cutter
Post by Scott_Conger » Fri May 17, 2019 1:16 pm
These people are very nice and know which cutter heads to sell you to do a T. Just tell them and someone will come to the phone that can help.
http://www.newaymfg.com/cutters
Last Name: Hatch
Post by Dan Hatch » Fri May 17, 2019 1:47 pm
At my space at Luray. I have Van Dorn valve seat grinding set. Dan
RGould1910
Last Name: Gould
Post by RGould1910 » Fri May 17, 2019 5:52 pm
Bit of caution on using adjustable pilots supplied by Neway. If any speck of dirt gets into the spline, you wont get the cutting head correctly aligned. I don't know if they make the right size solid pilots for both T oversize guides, since I purchased the adjustible ones. If I had to do it over, I'd go with the solid pilots. If Neway doesn't have them, I'd check other suppliers. Away from home now, but I think have a catalogue of another source, but don't remember their name. If interested, email me at rgould1910"at"comcast.net.and I'll find the catalogue when I return in a day or so.
Richard
Post by Scott_Conger » Fri May 17, 2019 5:59 pm
Richard
EXCELLENT and correct point! I have trouble making the adjustable guides work perfectly, too. You can purchase any solid guide you want, though, and I have subsequently invested in a number of them. Very good of you to make that point.
