Thanks,
Michael
WTB 1912 Double Stack Magneto Coil
michaelb2296
Topic author - Posts: 263
- First Name: Michael
- Last Name: Bunner
- * REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Joe Bell
- First Name: Joe
- Last Name: Bell
Re: WTB 1912 Double Stack Magneto Coil
Lucius family rebuilds them every day, they are the supplier for all 419-595-2310. Hope this helps
JvanMaanen
- First Name: Jim
- Last Name: Van Maanen
- * REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
Michael,
I may have a double stack that came on a Dec 14 block and transmission. Not sure if there is a difference between the 12 and what would be a 15, maybe someone here knows. I'll try to get you some pictures emailed to you in the next day or two. It has been sitting on the shelf for 20 years, but in a dry heated shop.
Van
Van
JvanMaanen
- First Name: Jim
Sorry Michael, checked it out and it is a single stack, oval spool for 17-18 non starter car, so not what your looking for. Joe's contact is probably best bet.
Van
Van
Joe Bell
- First Name: Joe
- Last Name: Bell
1912 will have the sheetmetal plate with 1/4 double stack, made for the 5/8 magnets unless it has been changed?
- Last Name: Hatch
We know the rebuilder has some cores don’t we Joe? Dan
Don ellis
- First Name: Don
- Last Name: Ellis
- * REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
I have the pressed steel and the cast if you're still looking.
