Wood band question
colonelpowers
First Name: Joshua
Last Name: Powers
* REQUIRED* Type and Year of Model Ts owned: 1922 Center Door Sedan
Wood band question
Post by colonelpowers » Thu Aug 17, 2023 10:24 pm
I just wanted to ask a question about wood bands. It is time for new linings and thought that I would try wood but I wanted to ask if you have to pull the hogshead to install them. I have a 26 with quick change bands. If it requires the hogshead to come off I will probably go with Kevlar instead.
Re: Wood band question
Post by Scott_Conger » Thu Aug 17, 2023 10:36 pm
Off it comes!
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri Aug 18, 2023 6:42 am
Colonelpowers.... For what you're asking, wood lined bands with detachable ears can be installed with a transmission cover intact. First off, as with any re-lining project, you would need a transmission drum as a guide to adjust and bend the metal bands to conform to the drum before installing lining. On installation they could be fed in through the transmission inspection door and then secured with lock, washer and nut. Band adjustments should be followed by the Ford service manual.. https://youtu.be/2uhM4DPE0Fchttps://you ... uhM4DPE0Fc
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Fri Aug 18, 2023 7:31 am
If this is your first time just plan on pulling the hogshead regardless of band choice. It can be done thru the inspection plate with much more cussing.
Post by speedytinc » Fri Aug 18, 2023 8:21 am
Either require a HH pull. If your goal is to not remove the HH, go with scandia or cotton.
Mangling your bands installing thru the inspection door is an invite to disaster with kevlar.
Post by RajoRacer » Fri Aug 18, 2023 11:35 am
The one & only time I attempted wood lining replacement through the "hole", half of the rivets pulled through & cracked the wood !!!
RGould1910
Last Name: Gould
Post by RGould1910 » Fri Aug 18, 2023 10:28 pm
Good info Steve!
Moxie26
Post by Moxie26 » Sun Aug 20, 2023 12:55 pm
Colonel Powers.... How's your progress with the band change coming along?
