FS BOSCH DISTRIBUTOR (NOS) IN THE BOX (SOLD)
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Fri Aug 18, 2023 1:51 pm
BOSCH Magneto Corporation distributor in the original box. Absent shelf wear, it appears unused. Price is $300 plus $18.50 domestic shipping. Mark Chaffin (951) 805-0928 SOLD
Re: FS BOSCH DISTRIBUTOR (NOS) IN THE BOX (SOLD)
Post by TRDxB2 » Fri Aug 18, 2023 5:47 pm
I am correcting my original entry. I hadn't ever seen this version of a American Bosch Distributor or even ads for it. Now I have paper work & documentation to go with the other versions. The instructions seem to be the same for the two different versions -correct?
Configuraions
These have different centrifugal advance mechanisms and how they the body is attached to the timing plate
Type 600-D.png (572.67 KiB) Viewed 734 times
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Fri Aug 18, 2023 6:31 pm
With all due respect, I believe you are mistaken. The distributor looks identical to the one in the included instructions.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Aug 18, 2023 6:58 pm
The Type 600 is a unique duck for sure, uses one vibration coil with the flywheel magneto coil or a conventional added coil.
Rare find!
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Fri Aug 18, 2023 7:05 pm
You are correct. Thank you Hank! :)
