Form A Truck
Charlie B in N.J.
Topic author - Posts: 786
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Form A Truck
Found at the Allaire State Park Rolling Iron Car Show here in Southern N.J. First time I’ve ever seen one in person. This unit was installed on a 1917 Touring car and had a home made cab and rear wood deck. Set up with a crane and hand winch for car towing. Quite a lot of work goes into one of these kits. The entire Ford running gear is intact with a frame extension added to the rear of the chassis. Chain drive. Those rear wheels are massive. Tight picture I know. They were packed in pretty close. Any one know the price of one of these kits?
TractorGlenn
- First Name: Glenn
- Last Name: Heim
Re: Form A Truck
Did you get any information off the nameplate on the frame? I have seen two others with the same wheels and pinion sprockets and both are missing nameplates. Sure would like to know what company was the builder. Did you get the name of the owner?
Charlie B in N.J.
- Last Name: BRANCA
