Scandinavian Bands soaking or not?
Fozz71
Last Name: Chochole
Board Member Since: 2003
Post by Fozz71 » Fri May 17, 2019 9:39 pm
I haven't put Scandinavian bands in a T in almost 20 years but I am going to soon, do folks still find that pre-soaking them in oil is the best method?
Thanks,
Jim
Nv Bob
First Name: Bob
Last Name: Middleton
Re: Scandinavian Bands soaking or not?
Post by Nv Bob » Fri May 17, 2019 10:07 pm
Jim
I used to now put them in dry
Add a quart of oil over them after installed
Never had an issue in 20 sets doing it this way
Oh dint drain extra oil out yhe top pet cock
Post by RajoRacer » Fri May 17, 2019 10:14 pm
I pre-soak for a couple days - everyone does what works for them.
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Post by Jim, Sr. » Fri May 17, 2019 10:21 pm
Put the bands in and close up the cover. Start the engine and let it idle for a while. With all that oil splashing around they will be soaked up quickly.
1922 Coupe , 1926 Touring
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
* REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
Post by Kohnke Rebabbitting » Fri May 17, 2019 10:36 pm
Agree!
Herm.
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Sat May 18, 2019 8:19 am
I soak them in automatic transmission fluid. I have changed one lining without soaking successfully, but next time I changed it the rivets didn't want to go in as they should. Change of material perhaps? I soaked it and no problem.
