WTB crank
joshboogie
First Name: josh
Last Name: king
WTB crank
Post by joshboogie » Mon Aug 28, 2023 2:32 pm
WTB nice crank that would mag and grind 10-30 . I did a no-no to my last one and bent it. MEL.
joshboogie
First Name: josh
Last Name: king
Re: WTB crank
Post by joshboogie » Mon Aug 28, 2023 2:40 pm
call 757-469-9420
First Name: craig
Last Name: leach
Re: WTB crank
Post by Craig Leach » Tue Aug 29, 2023 12:13 am
Hi Josh,
How did you bend the crank? Every time I have one ground they bend it & I have to straighten it or send it back & have them straighten it!
30 is a lot ( I have no room to talk I have a Std. 10, 20, 20, 40 in one engine ) If you straighten it make sure the flange is straight or that is an
other can if worms. Many T cranks can be ground 10-10 but make sure to check the seal area & the flange. Hope you come up with a solution.
