brass tags
Melba Nolan
First Name: Melba
Last Name: Nolan
* REQUIRED* Type and Year of Model Ts owned: 23 roadster
brass tags
Post by Melba Nolan » Sat Sep 02, 2023 3:12 pm
Can someone tell me what these brass tags are for. They are round and oval with numbers on them. Also on a steering shaft what is the difference between a round top and a triangle top. Couldn.t post picture.
Moxie26
Last Name: Jablonski
Re: brass tags
Post by Moxie26 » Sat Sep 02, 2023 4:41 pm
Looking at those tags with numbers, would they indicate a date like 321, that could match March of 2021?. Some of us who do rebuild things could put such a tag on a differential housing, steering column starter or generator, or even have numbers impressed into the wood of an ignition coil..... That would indicate when the item was rebuilt or refurbished.
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: brass tags
Post by Melba Nolan » Sat Sep 02, 2023 4:58 pm
the oval tags are about 2" wide and about 1" 1/4 high. some have. some of the numbers are: 0 - 2 1/4 - 1/2 -2 1/4 - 1 3/4 -1 - 2 and the round ones are an inch in diameter with the number 2 and 150. the 1.5 inch diameter has 544 and the others are blank
Re: brass tags
Post by RajoRacer » Sat Sep 02, 2023 5:08 pm
Regarding the steering shaft - only round ones I've seen were the reproduction Texas T Parts - Ford had a triangular top.
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: brass tags
Post by Melba Nolan » Sat Sep 02, 2023 8:32 pm
thanks for the info on steering.
Re: brass tags
Post by Original Smith » Sun Sep 03, 2023 11:13 am
How about some photos?
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: brass tags
Post by Melba Nolan » Sun Sep 03, 2023 5:39 pm
couldn't post. can email or text
