What have you done to your Model T in September?
Bill Everett
First Name: Bill
Last Name: Everett
Board Member Since: 2011
Post by Bill Everett » Sat Sep 02, 2023 9:46 pm
Body making progress.
Parts taken to become a car.
Re: What have you done to your Model T in September?
Post by Steve Jelf » Sat Sep 02, 2023 11:55 pm
What I did to my T today was hit the big mama of all potholes. It knocked off a headlight rim and broke out the glass. I reckon I'll be looking for a glass shop when I get to Michigan. :)
Post by Allan » Sun Sep 03, 2023 7:07 am
Father's Day here, and my son worked on the replacement generator for Henrietta. He has asked for input with his work in another post. This is a rebuild of a good patina matching unit for the old girl. New sealed bearings, undercut and machined commutator on a tested arnmature, new insulation on fieds leads and a new terminal wire soldered to the terrminal bolt, and all new brushes. Fortunately the insulation on the brush holder plate was undamaged and adjustment of the third brush will be easy.
All in all, not a bad day.
Jlenon
First Name: Josh
Last Name: Lenon
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Post by Jlenon » Mon Sep 04, 2023 11:14 am
So far I've just been swearing at it. :lol:
Ken Lefeber
First Name: Ken
Last Name: Lefeber
Post by Ken Lefeber » Tue Sep 05, 2023 5:00 pm
Cleaned out the sediment bowl, fuel line, and fuel bowl after Wilma wouldn't start.
Then took her for a test drive to the pie iron cooking demonstration at the State Park.
No problems.
Pie Iron Display.JPG (59.02 KiB) Viewed 11408 times
Vintage Pie Iron Packages.JPG (52.19 KiB) Viewed 11408 times
Various Pie Iron Designs.JPG (54.78 KiB) Viewed 11408 times
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Tue Sep 05, 2023 8:26 pm
Had done the tie rod and spindle bushings in June, today I replaced the gears and driver in the steering gearbox from an old column I had. Much tighter now. :)
abcarswell
First Name: Bruce
Last Name: Carswell
* REQUIRED* Type and Year of Model Ts owned: 1924 Model TT, 1934 Fordor
Post by abcarswell » Fri Sep 08, 2023 4:31 pm
A minor thing but a huge improvement to drivability of my TT. I decided to purchase one of the Depot hack rear view mirrors from Langs to see if I could mount to my C cab and eliminate the clamp on mirrors that are nearly worthless. I had to drill and tap the bracket to reorientate the mounting 90 degrees but wow! I can actually see backing up and mirror does not vibrate to the point of making it useless. I was a little nervous drilling into my cab but it now looks like it’s always been there. Now for the other side.
AandTman
First Name: Donald
Last Name: Vagasky
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster 26 Touring 25TT C Cab express 26 Ames Speedster
Post by AandTman » Fri Sep 08, 2023 4:44 pm
Got the rear doors aligned buy tweeking the hinges for proper gap, and shimming the bed to remove a slight twist. The door mechanism is still hard to operate. Will work on that.
Arbs
Last Name: A
Board Member Since: 2022
Post by Arbs » Fri Sep 08, 2023 11:08 pm
Replaced the wood in my coil box with plastic.
I felt dirty doing it. I know it's a slippery slope with these small deviations from original. Next thing you know I'll be contemplating a water pump... Or a fuel filter... What have I done? :lol:
Post by speedytinc » Fri Sep 08, 2023 11:13 pm
Welcome to the group. The first step is realizing you have a problem. :o
If you feel the need to further stray, we'll talk you down.
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Post by Joe Reid » Fri Sep 08, 2023 11:35 pm
Some things only your hairdresser knows! Here is a serious deviation, a distributor and 12 volts. I wouldn’t have done it if the magneto had not quit. It is also a Johnny Cash car with lots of spare parts.
Arbs
Last Name: A
Post by Arbs » Sat Sep 09, 2023 10:22 am
Looks like a fun ride and a head turner!
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sat Sep 09, 2023 10:55 am
Re-bushed the front spindles.
Arbs
Last Name: A
Post by Arbs » Sun Sep 10, 2023 4:51 pm
Stopped at a farm stand and by chance took the old girl to her native habitat... a no winter maintenance gravel road... I could have turned around but I just took it slow and let her suspension get some exercise.
It looks like this road is smooth but once I headed down hill it had plenty of erosion ditches to navigate. No time to take photos there.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sun Sep 10, 2023 5:47 pm
Some static balancing of transmission parts
flywheel
drive plate and brake drum
slow speed drum
reverse drum. All the mandrels where turned on the lathe. The flywheel used a cut transmission shaft and the rod is a .750 stainless steel precision ground rod from an old milk bottle filler. .750 id ball bearings with grease removed and light oil added. Used leveled jack stands to hold it. Ended up very sensitive to weight. I think I have about $12 in it.
Bryant
George Mills
Last Name: Mills
Post by George Mills » Mon Sep 11, 2023 1:19 pm
I had chased my ’15 for 20 years before I was able to buy it in an estate sale. I knew the provenance of the car from him, and also the guy before him who was still around early in the chase, who bought it 'way back when' from NJ Bell where it was in dusty storage at a depot corner with one of those salesmens boxes. Other than changing the salesman box into a real ‘turtle’ the car between the previous owners had less than 100 miles combined, and from the look of the tranny, Bell Tel had parked and locked this thing very early on in its life. That said, the side lamps and tail lamp looked like something owner #2 had laying around his acres and acres of ‘stuff’.
So…I get the car, the lights don’t bother me too much and then in the early days of T-bay there is a set of restored lamps, totally restored, for a ’15 it said. I hopped on it right away, a well-known T guy from New England had the same thought. Whatever I bid, he’d turn around and bid higher but he wasn’t auto bidding. So I chose ‘bid butler’ at a level max I knew anyone would give up before reaching. Shortly after, the lamps were mine and I proudly mounted them immediately.
Trouble eventually was, I didn’t know what a specific ’15 specific kero light set was supposed to be! I had been a black car guy for the first 20 years! Brass chimney tops…check. Brass ‘glass door bezel’…check. All the rest powder coated black…check. Reflector replated…check. Turns out the guy that lost the bidding was the real winner. The set of lamps eventually was learned to be pretty much ’25 or so. The rebuilder had BRASS PLATED the chimney cap and the glass bezel…the hinge pins were nails used as rivets…but what the heck,,,bought a repo set of chimney caps with the engravings and all was good appearance wise, right? Then along comes our buddy Art V and his well-researched and consensus agreed graphics. Hmmm. Chimneys now all wrong, reflector inserts now all wrong, font bowls now all wrong…and I didn’t care! Until the son decided to take over the stewardship of the ’15 at his place! He honkered down on that and really took a purist approach to a 95% complete and accurate low mileage Roadster and getting it to as close to 100% as he could. I in turn took on the secret project of making the side and tail lights ‘correct’. That did happen over the last year or so due to generosities, outright donations from great people and some of the whacky hard to find stuff being available to buy from guys all over the USA.
Side lights went on in April…but no picture. Taillight went on this past weekend…I get just as much fun puttering on the little things as I use to get driving the car!
RGould1910
Last Name: Gould
Post by RGould1910 » Mon Sep 11, 2023 3:57 pm
Repaired a broken horn bulb bracket. Langs says the soldered joint often breaks. Mine did. I saw no sense In resoldering so I did a mechanical repair with a 10 32 machine screw and a small copper washer using blue Loctote to hold things tight.
RGould1910
Last Name: Gould
Post by RGould1910 » Tue Sep 12, 2023 2:43 pm
Finished the windshield bumpers.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Wed Sep 13, 2023 2:04 am
Richard- the problem with those horn brackets is they are put together with soft solder. The only way to make them stay together- both on the horn tube and the body side bracket is to desolder them and then put them back together with silver solder.
First Name: Jeff
Last Name: Humble
Post by Humblej » Wed Sep 13, 2023 8:45 am
Richard,
That brass looks great.
By the way, there is not a lot of thread engagement on some of those nuts, you may want to use longer bolts.
RGould1910
Last Name: Gould
Post by RGould1910 » Sat Sep 16, 2023 12:12 am
Thanks for the input. I considered silver solder but opted for a mechanical repair. I the other end comes apart, I'll go with silver solder because ther is no way to install a screw.
Your observation prompted me to use Loctitie.I think there is enuf thread engagement to hold things togther.
RGould1910
Last Name: Gould
Post by RGould1910 » Sat Sep 16, 2023 9:00 pm
I know I've probably posted too much about my 1912 roadster but I am celebrating g a 20 year effort (on and off) to complete this restoration. Today I finished. Still have to bring the car to Ernie Romero next Spring for a top and waiting to meet with Russ Furstnow at Tulare for help with the speedometer. But for now it's done. Many thanks to all those that offered help and encouragement along the way. Too many names to list but accept a heartfelt thank you.
Distagon2
Post by Distagon2 » Sat Sep 16, 2023 10:53 pm
Magneto work on my 12 Roadster. One of the more tedious jobs on a Model T, IMHO, but you just gotta have a working mag!
Distagon2
Post by Distagon2 » Sat Sep 16, 2023 10:58 pm
Congratulations on your beautiful 12 Roadster, Richard. It looks fabulous and you must have quite a sense of accomplishment. You can't post too many photos of that beauty! Good luck with the top-I will be facing that part of the restoration in about a year.
RGould1910
Last Name: Gould
Post by RGould1910 » Sun Sep 17, 2023 12:21 am
Thank you Greg for your kind words. Let me know if I can be of any help on you restoration. 😀
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Post by Model T Mark » Sun Sep 17, 2023 11:57 am
Painted this Friday. 18 touring it was a burned body sometime in its life.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Sun Sep 17, 2023 8:24 pm
Just made this one running.
Andre
Belgium
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun Sep 17, 2023 11:13 pm
I broke the crankshaft in my 1915...
AndreFordT
First Name: Andre
Post by AndreFordT » Mon Sep 18, 2023 1:18 am
Here the running engine.
https://www.facebook.com/hans.devos.351 ... &ref=notif
Andre
Belgium
Post by speedytinc » Mon Sep 18, 2023 11:11 am
I notice your pistons dont have the lubrication holes for the wrist pins.
Is it possible that the wrist pins got tight & caused the extra strain to break the crank?
I ask because I also broke my crank behind #1. The only issue I can point to is tight wrist pins.
Anybody experience the same?
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Sep 18, 2023 1:25 pm
John-
Broken cranks are a mystery. I think the #1 reason is a bent pan that contributes to metal fatigue. When I put this engine together the short block was done. I straightened the pan, put the transmission on and have had nearly 30 years of trouble free touring.
John_Aldrich
Last Name: Aldrich
* REQUIRED* Type and Year of Model Ts owned: 1915, 1923. 1927
Post by John_Aldrich » Mon Sep 18, 2023 2:38 pm
Replaced an aluminum timing gear with a bronze one to reduce engine noise.
John Aldrich
Typical Model T Addict
RGould1910
Last Name: Gould
Post by RGould1910 » Mon Sep 18, 2023 5:19 pm
Keith I'm hoping you can get another crankshaft ground to the sames specs as the broken one and not have to disturb your rods and mains much. Mabe just light fitting with Timesaver. Erik Barrett has a whole bunch of good crankshafts. I've has good luck using Carl Grindstaff in Redding to grind T crankshafts and axles to my specs.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Fri Sep 22, 2023 9:07 pm
We planned this about a week ago. I loaded up my neighbors and all their kids and grandkids in the TT and went for about 20 mile round trip for icecream. There were 19 of us enjoying a nice evening fall ride. The oil lights are not that bright in the back and even tho I have clip on LED flashers, I had my wife follow us home in the modern iron as it was really dark when we got home. After my visit with Steve Jelf this morning, it was a great end to a great day.
Last Name: Hjortnaes
Post by DHort » Fri Sep 22, 2023 11:53 pm
Did you get a chance to race the bishop?
kelly mt
Last Name: Kelly
Post by kelly mt » Sat Sep 23, 2023 1:06 am
I put 375 miles on my '27 Tudor touring the Salmon River country of Idaho. Had to adjust the low band but the car ran pretty good. Had lots of help from friends who got under the car to check things out.
[attachment=1
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sat Sep 23, 2023 7:40 am
Very small but important. Bought two radiator shells and both were broke. Cut the rivets off one hood rod support bracket from the ripped shell #1 and welded it to a piece of stainless steel. Drilled four holes in shell #2 and plug welded through the brass to the steel underneath. Then connected the plug welds on top. All photos are shell #2.
Vern (Vieux Carre)
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Sep 24, 2023 3:26 pm
We had EVOC training at a neighboring fire department yesterday. I drove the RPU to breakfast and then a 9 hr class and driving test. Best part of the day was there and back.
Last Name: Strange
Post by CudaMan » Sun Sep 24, 2023 3:40 pm
I drove both my 1924 cut-off touring (now a pickup) and my 1912 Flanders this morning. The trip in the Flanders was only about 5 miles, I'm still building confidence in the car. I did one of my normal 16 mile out-and-back trips in the T. :)
Bryce S.
First Name: Bryce
Last Name: S
Post by Bryce S. » Mon Sep 25, 2023 7:59 pm
I love the look of that 24'. I'm hoping to get something similar to that eventually.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Sep 25, 2023 8:15 pm
Bryce I agree! This one I built for my dear friend and mentor Dr Gary Flandro, NASA Astrophysicist and the guy that came up with the Voyager 1 & 2 probes as an intern at Cal-Tech. This is a steel clad over solid oak and black walnut.Enjoy!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Sep 25, 2023 8:24 pm
I haven't done squat! Prior commitment and promise to build a custom patio from 15 years ago! I wish my wife would learn to forget somethings!
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Mon Sep 25, 2023 8:36 pm
I hear ya Hank. Looking great. 15 years ? I could only take it ten years before I had to build my wifes training building. No! Not for me but her dogs.😁
TFan
First Name: Jim
Last Name: Riedy
Post by TFan » Mon Sep 25, 2023 11:16 pm
Two weeks ago I took my neighbor's son and his girlfriend for a parade ride they were attendants for the prom at our local catholic school. Jim
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Tue Sep 26, 2023 12:25 am
I got my broken crankshaft halfway out...
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Tue Sep 26, 2023 1:49 am
Installed data plate. Also, stamped the non-original, serial number plate and mounted on firewall.
Mounted terminal block on firewall and wired it and instrument panel.
Vern (Vieux Carre)
