Full Flow Float Valves™ for NH, Vaporizer and Simmons (Wizard) - Sold out for 2025
Post by Scott_Conger » Fri Sep 08, 2023 11:11 pm
The only float valve on the market that flows as well or better than Henry's original.
If you wonder if they work, simply ask the guy who just passed you.
Email for details - I do not monitor this closely enough to answer questions promptly
standard vs full flow.jpg (32.95 KiB) Viewed 11883 times
Last edited by Scott_Conger on Fri Dec 05, 2025 10:33 pm, edited 7 times in total.
Rjackson
First Name: Ron
Last Name: Jackson
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster 1925 coupe 1923 Tudor 1927 speedster
Board Member Since: 2014
Re: Full Flow Float Valves for NH, Vaporizer and Simmons (Wizard) - continuously available since 2019
Post by Rjackson » Tue Dec 19, 2023 12:05 pm
Hi Scott would like to buy 2 or 3 valves for nh carbs
My name is Ron Jackson phone is 720-720-4744
Thanks Ron
Tinner12
First Name: Vernon
Last Name: Enis
* REQUIRED* Type and Year of Model Ts owned: 1917 and 1924 touring,1926 4 door
Board Member Since: 2011
Re: Full Flow Float Valves for NH, Vaporizer and Simmons (Wizard) - Now shipping for 2024 touring season
Post by Tinner12 » Sat Aug 17, 2024 7:35 am
I would like to buy a set of float valves if they are available, Im just finishing a 1926 4dor. I'm having a NH rebuilt for it Vern Enis 509-671-1382
TeveS-Nor Cal
Last Name: Straw
Post by TeveS-Nor Cal » Sun Aug 18, 2024 11:19 pm
Are you shipping to CA this season?
Re: Full Flow Float Valves™ for NH, Vaporizer and Simmons (Wizard) - Back in stock!
Post by Scott_Conger » Sun Mar 02, 2025 2:22 pm
2025 production complete and ready for shipment
Don't let Summer '25 tour season pass without upgrading your NH and get the most out of your car this year!
I constantly request EMAIL ONLY - DO NOT SEND PM's
Yes, I'm shouting, because for whatever reason, folks who send PM's often refuse to go back into the system to retrieve my response and it is maddening - therefor:
IF YOU DO NOT HEAR FROM ME IT IS LIKELY BECAUSE YOU DID NOT RETRIEVE MY RESPONSE OUT OF THE SYSTEM - I PRESENTLY HAVE 3 PEOPLE WHO ASKED QUESTIONS AND THE SYSTEM TELLS ME THAT THEY HAVE FAILED TO LOOK AT MY RESPONSE
I can only write the response, I cannot make you read it!
Valve bodies fresh out of the cleaner, waiting for packaging
Re: Full Flow Float Valves™ for NH, Vaporizer and Simmons (Wizard) - Sold out for 2025
Post by Scott_Conger » Fri Dec 05, 2025 10:36 pm
2025 production sold out
new production valves available approximately March 2026
thank you to everyone who bought one this year and in years past!
my largest production run sold out in record time and I will be increasing my numbers for next year so as to hopefully not run out
