Loading Trailer for Hershey Pictures added
Topic author - Posts: 5545
- Last Name: Hatch
Loading trailer. 1914 WT Front Fenders, NOS 23/25 Sedan Rear Fenders, 13/14 Rear axle housings, 26/27 Wire wheels and hubs 2sets, couple of 14 windshields, Early brass windshield with rods, Forged end Radius Rods, 1914 Coilbox with lid, 1915 Coilbox with lid, 26/27 Coilbox with lid, big drum rear housings and Safety hubs, T tire pump, 13/14 Hogs Heads, NOS or early take off 1925 Front fender, reproduction early Top Irons and bows, Touring cowl top, dashboards, high firewalls, some Model A parts, Early V8 parts,
More to come.
Spaces CR 33/38
More to come.
Spaces CR 33/38
- Last Name: Hatch
Re: Loading Trailer for Hershey
Stevens Front Axle Inserts, Rebuilt Front Axle, DB Front Axle, crankshafts, more to load.
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Nice 1913/14 rear fender, pair of pass side 25 front fenders. 17-25 driver side rear fender nice,
These two sets of top irons Have new wooden bows for them too
May be a14 touring body in pieces.
- Last Name: Hatch
Re: Loading Trailer for Hershey Pictures added
11/12 Brassworks radiator No Made in USA, used very little maybe 6 months.
Needle nose pans, 1914 Windshields, 21” wood wheels with rims and tires.
26/27 wire wheels and hubs.
Cast iron rear radius rods
1915 rear end complete came out of running car. Put only if you say you want it before I leave.
- Last Name: Hatch
Couple Dorman parts cabinets.
30x3 rims and a square fello wheel
1911 gas tank
1911 Kingston 5 ball
1911 gas tank
DustySpokes
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Hi Dan, email sent about the 1911 Gas Tank - Dusty
- Last Name: Hatch
More stuff just found.
1915 Steering column
1913/14 Steering column nice
Tea cup pan with early nose. You know what I mean if you know early pans
Forged cam hand brakes nice one
Cleaning out my I have a dream stuff.
CR-33 to 38.
CR-33 to 38.
- Last Name: Hatch
Just made another run from to one of my buildings. Adding these
Another nice 14 Steering column
1913/14 mufflers assy (2)
30x 3 square fello wheel looks like early takeoff or NOS
30x3 round fella wheel
13/14 alum intake
CR-33/38
13/14 alum intake
CR-33/38
- Last Name: Hatch
Tapered leaf rear spring
TT 8 leaf front spring NOS
Lots of NOS Front spring Main leafs
Small Drum Closed Spool Ruckstell kit.
Also 2 Low heads, vatted and pressure tested cracked but easy fix.
- Last Name: Hatch
Back to the t
- Last Name: Hatch
42-48 NOS Front brake drums
Some model A parts, box full
Roll of top material
Mike Lebsack-Iowa
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
- Last Name: Hatch
One more thing NEW 1911-12 round gas tank. Has outlet on the end. Screw in not the little cup outlet like 09 to early 11.
Cr-33/38.
Cr-33/38.
RGould1910
- Last Name: Gould
- Last Name: Hatch
Stevens Front Axle inserts
Round gas tank
Nice Ford Air gages
KRW engine stand adapter looks to be from 50s.
Round gas tank
Nice Ford Air gages
- Last Name: Hatch
Just found something else.
1914 Touring Front or Roadster door. These only fit that year and nothing else. Nice door, hard to find!!
Late 14 Steering column, has a pressed steel lever rest instead of a brass one. Not made like the later pressed steel rest.
Only one I have ever seen.
Steves Ts
- First Name: Steven
- Last Name: Meudt
- * REQUIRED* Type and Year of Model Ts owned: 1913 touring / 1913 delivery / 1917 roadster / 1914 roadster pick up
HELLO, By chance do you happen to still have Your 1914 roadster door ?
Steve
Steve
joshboogie
- First Name: josh
- Last Name: king
I still need a nice 30by3 rim for a 1915 how much? MEL King.
vping
- First Name: Vincent
- Last Name: Pina
- * REQUIRED* Type and Year of Model Ts owned: 1925 Tudor Sedan
How about a 21" KH split rim?
