Finned RAJO exhaust manifold question
Popemcman
Topic author - Posts: 1
- First Name: Mike
- Last Name: Morris
I have a finned RAJO exhaust manifold that is incomplete. The exhaust pipe exits from the bottom of the manifold. The missing part holds the exhaust pipe somehow. Does anyone know what the missing part looks like? Thanks. First time on the forum haven't figured out how to attach photos. Mike
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Finned RAJO exhaust manifold question
There is an extension piece that routs the exhaust down from the exhaust manifold and around the water connection casting. They are pretty rare.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
You can attach a header flange on some proper diameter pipe and it will work fine until you find an original.
22centerdoor
- First Name: David
- Last Name: Stauffacher
- * REQUIRED* Type and Year of Model Ts owned: 1922 Centerdoor
Actually, any competent muffler shop should be able to manufacture you a suitable header.
jelenbaas
- Last Name: Elenbaas
- * REQUIRED* Type and Year of Model Ts owned: 1914 Runabout, 1916 Delivery, 1925 Roadster PU, 1926 Speedster
Any idea the purpose of the 2 bolts coming out of the top of the manifold are for?
Not stock. Maybe for a carb air heat pipe.
